Results 1 to 9 of 9
Thread: What is this?
    What is this?
    It came with my '01 LT, and looks like it is absolutely essential if I want to do something.
    But what?
    Jun 2009
    Rochester, MN
    Are there internal threads?
    Maybe an aftermarket wireless tire-pressure-monitoring valve cap?
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    IF there are no internal threads - that kind of looks like a standard RCA phone plug... maybe a mini-antenna for the radio?
    No threads. The center pin is spring loaded, and they were on a ring with a spare key, key code, and the alarm fob. I thought possibly a quick release for the ignition key, but I can't see how that would work, either. Possibly something to do with the alarm system?
    Anyway, they're well made. Nicest ones I've ever had, I think.
    Mehrten
    Nov 2004
    Arizona, USA
    I believe it is an alternative alarm fob.
    On our 1998 K1200RS (or was it the 2004 K1200RS?) there was an OEM alarm.
    There was a fob like thing that you could press a button or two on to set or turn off the alarm.
    The other was the piece you show that went over a small, circular insert in the dash that would also turn the alarm on or off.
    It was handy to have when I would inadvertently set off the alarm in my back yard shop by mistake.
    That is the coding plug for the alarm system
    Sent from my iPad using Tapatalk Pro
    Brian Hinton
    2007 R1200R
    2007 K1200GT
    2016 R1200GS
    Quote Originally Posted by brianhinton View Post
    OK. Does anyone know what I can/should do with it?
    Geeze, you're really opening up to some comments on that ... but stash it in a safe place where you won't forget about it.
    Do they use batteries?? If so, renew it.
