Results 1 to 15 of 28
Thread: Jump Starting with car Battery?
    JohnWC
    Akron, Ohio
    My 96 R1100RT seems to always have a battery leak down problem. A few days off the charger and it barely cranks. A few weeks ago it get really low and it would hardly start, but did. Then, of course, the ABS lights showed a default. Normally after riding a few miles I can cancel them by restarting, but not this time. I had the Odyssey 680 battery supposedly load tested and it passed. 12.8 or so volts. It's about three years old. Took the starter off and had it tested, and it met the specs. Just put it back together and tried it, and again, pretty slow cranking, and the ABS lights flashing. I'm beginning to wonder if the battery is the problem after all. I thought I might try jumping it with my car battery to see if it cranks better, and if it then doesn't have an ABS problem, before I go buy another battery. If I do get another battery it will be back to a regular lead acid, which I believe GSaddict says is better for these models. Any thoughts on if I will burn up the electrical system on the bike with the larger car battery?
    Provided you connect the cables correctly and are using a 12 volt battery jump starting with a car battery will not harm the bike. The amount of current that will flow will depend on the draw of the bike's components and not on the capacity of the battery.
    Mansfield,MA
    I have jumped a bike with a car- no problem.
    https://forums.bmwmoa.org/showthread...died-yesterday
    I have found when a battery is left in the system, itís difficult to get to the root of the problem. A way to get closer to the problem, with the battery in-line, is to measure the available voltage while cranking the engine.
    If there is a severe draw-down, the battery is suspect.
    If the battery was removed from the system and run off the car......and ran fine, it would be another way to test the starting.
    Mod Squad
    2009 F800GS 1994 TW200
    Lanark County near Ottawa ON
    As Paul says the bike will pull the amount of current it needs from the car battery and not more BUT you should not boost from a car battery in a running vehicle. This is because the regulator in the bike (a crude shunt type in many cases) may attempt to regulate down the boosting vehicle's charging voltage. A shunt regulator will handle the full current output of the bike's alternator but not necessarily that of the boosting vehicle.
    Sent from my SM-T813 using Tapatalk
    May 2016
    St Lazare, Quebec, Canada
    No problem to boost from a car but MAKE SURE the car isn't running.
    Mansfield,MA
    Never had trouble jumping with running or not running
    I would try to avoid the start cycle of the donor vehicle during the attempted jump. Once the donor vehicle is running, unless there is some problem with the donor vehicle, itís stable.
    I have found that a ďjumpĒ is no problem with a stable power source.
    Mod Squad
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Quote Originally Posted by RadioFlyer View Post
    Oilheads & Hexheads do not have shunt type regulators. You can safely jump with an external source.
    Waterheads on the other hand, do. It would not be wise to jump from a running vehicle, especially if revving high.
    Ufda happens..........
    Mar 2019
    Catskill MTS
    I will make sure the car is no running other wise you have a good chance of burning out the ECM. I seen it happen more the once. You are better of giving the battery a full charge as with a low battery you are putting more strain on the electrial system.
    The F bikes also have shunt regulators. I don't know about the S or K bikes.
    I was responding to a boxer thread.
    I was just trying to demonstrate thar the earlier boxers are the exception. Shunt type regulators are very common on bikes.
    Of course, because they're cheaper.
    JohnWC
    Akron, Ohio
    I'm still assembling the wires needed to jump start the bike from a car battery. But before I did that I wanted to check the voltage draw from the Odyssey battery alone. This is it:
    1) Battery voltage reading after being on charger= 13.3 v
    2) With the key switch turned on (headlights, dash lights) =11.8 v
    3) Cranking the engine= 8.2 v
    4) With engine started and running= 14.1 v
    Admittedly, this is when the temperature is a 22 degrees. But as I stated before, this was causing problems at somewhat higher temperatures also. I would guess that 8.2 volts is well below what it takes to trigger the abs fault light. Anyone know what that threshold is? So, a) even though the starter read an 80 amp, and roughly10 volt draw off the bike, on it it seems to be pulling a lot more, so maybe it is actually broken. Or, b) like my 1972 Ferguson backhoe with no glow plugs, these bikes shouldn't be started and run below about 50 degrees. Any thoughts?
    Mansfield,MA
    I would say itís time for a new battery.
    Mod Squad
    Quote Originally Posted by jconway607 View Post
    A properly charged Odyssey in good condition will crank at over 11v.
    The motronic does function correctly at 8.2v
  1. Jump Start Battery pack for C650GT Scooter
    By apwilson54 in forum Scooters
    Last Post: 03-09-2017, 06:47 AM
  2. Jump starting my 2015 R1200GSA
    By 1der in forum Wetheads
    Last Post: 06-01-2016, 12:48 AM
  3. Jump-starting an RT?
    By themayer in forum Hexheads/Camheads
    Last Post: 09-16-2010, 06:08 AM
  4. Replies: 7
    Last Post: 02-17-2010, 04:15 PM
  5. Low battery voltage when starting?
    By Muneio in forum Oilheads
    Last Post: 12-20-2007, 02:14 PM
