Results 1 to 13 of 13
Thread: Is My Timing Wrong? Or When to Bleed Brakes?
Hybrid View
    RK Ryder
    London, Ontario
    With both my K100 an R1100 RTs, I put them away for the winter with a full service, either the 10,000 or 20,000 km, with the exception of bleeding the brake lines. That I do in either late March or early April before either bike is back on the road.
    It has been bought to my attention that bleeding the brakes would better for the system if done before the bikes sit for the winter, rather than in the spring.
    So, spring brake bleeding or just before winter hibernation?
    Paul F. Ruffell
    Niagara Riders & Knights of the Roundel #333
    Liaison 20774's Avatar
    I'm going to add a little context to the thread title. I thought it might have been about ignition timing!
    Mar 2018
    Scottsdale, AZ
    So did I!!
    To lend a prospective to the question.
    I would most certainly bleed the brake system when the fall service is done.
    Brake fluid attracts moisture, when moisture and brake fluid are mixed together it becomes acidic. Thre mixture then eats away at the aluminum in your master cylinders and calipers. Think about the riding you did all season, the weather you rode through, the temperture changes from warm days to chilly evenings. These conditions creat condensation in your system, that brake fluid is sitting in your brake system through out the winter. Replace it with new and clean for storage. My $.02....
    Mansfield,MA
    Quote Originally Posted by CNRed View Post
    So did I!!
    I like this explanation.
    I donít worry a ton on BB as it is a sealed system unlike the constant opening and closing of a fuel system (ethanol) allowing the accumulated moisture to cause the same corrosion problems.
    Mod Squad
    2009 F800GS 1994 TW200
    Left Coast Rider
    Agreed with all of the above. Change all the fluids and be ready for spring.
    And if you haven't already, change any rubber brake lines for something from Spiegler.
    rabid reader dbrick's Avatar
    Santa Cruz CA
    I disagree. A vehicle hydraulic system is not sealed, as there must be a way for air to enter (and leave) the system to accommodate pad wear. Pad wear will cause the wheel cylinder pistons to "rest" in different positions within the wheel cylinders, thus affecting the working volume of fluid within the system.
    It's not a lot of air, as the volumes we're talking about in bike systems are small. But air does enter, and over time, brake fluid is degraded. There's a reason the manufacturers put "brake fluid replacement" in the maintenance schedules. On bikes, fluid change is usually called for at shorter intervals than in cars and trucks, because a) the master cylinder (where the vent must be located) is more exposed to weather on the handlebar compared to a car's master cylinder under the hood, and b) because a car's system, being larger, has a larger volume of brake fluid, and can tolerate a longer period between changes.
    As to changing in the fall of spring, I think fall makes the most sense.
    David Brick
    Santa Cruz CA
    2007 R1200R
    RK Ryder
    London, Ontario
    Well I will now have one less task to perform in the spring since I'll be bleeding the brakes in the fall.
    Thank you to all who replied.
    Besides doing the bleeds in the fall, would there be any advantage to doing a partial bleed mid-summer or is the fall service sufficient for all of the following riding season?
    Paul F. Ruffell
  1. ABS Brake Bleed
    By dennis50 in forum Oilheads
    Last Post: 06-13-2018, 11:20 PM
  2. Replies: 11
    Last Post: 06-01-2016, 12:47 PM
  3. ABS 11 Bleed
    By wbbaz43 in forum Oilheads
    Last Post: 03-01-2014, 03:51 PM
  4. '87 K7s - can't get brakes to bleed
    By kentuvman in forum Flying Brick K-bikes
    Last Post: 08-04-2012, 07:46 PM
  5. To Bleed or not to Bleed ?
    By RMRCLR in forum Oilheads
    Last Post: 08-14-2007, 04:21 PM
