Results 1 to 10 of 10
Thread: Wiring Denali D2 Lights on my 2004 R1150RT
    They call me Gort scootrp125x's Avatar
    Sep 2004
    Argyle Texas
    I just bought a set of Denali lights for my BMW. Can anyone offer any advice on wiring the lights into the bike. I have the side panels and tank off. I see a set of wires coming from the left hand grip. It looked like an easy installation however the wires in front of the forks are all wrapped up. I see a small wiring harness coming from the left handlebar switch. There also appear to be two individual wires coming from the left handlebar switch.
    I need to connect two wires, one to the low beam wire and one to the high beam headlight wire. I'm sure the headlight wires are there but can't really tell. My wiring diagram only shows two white wires going to the headlight, nothing shows the low and high beams. I can do oil changes and valve adjustments. Wiring is not my strong suit. Thanks for any help.
    Mark
    04 R1150RT
    skibum69 skibum69's Avatar
    Dec 2016
    New Melbourne, NL
    I think I wired mine back to the battery on my KTM 640. I really like them and yes they are bright!
    http://beerthief.ca
    ITSteve: ride in peace my friend
    save $5 on a new SmugMug account, use this coupon7frrnSRiTt9Fk
    Sep 2004
    Argyle Texas
    Thanks for the info. The wiring harness does connect to the battery however there are two more wires that allow the lights to turn on and off with the ignition switch. I can always buy a separate switch from Denali to turn the lights off and on manually but I like the idea that I don't have to remember to turn them off.
    04 R1150RT
    Dec 2016
    New Melbourne, NL
    I hear you, mine have the separate switch and Iím fine with that. Now I want to mount a pair on my 1100S but not much on the front end to work with.
    http://beerthief.ca
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Keeping in mind that I've never installed a Denali product (no issues, I just haven't) and haven't seen their instructions - maybe this would help:
    Behind the headlight is a plastic "dish" held on by a spring clip. Unclip it, and finagle (a high-tech term) it out of that tight space.
    The low beam wire is white with a yellow runner, coming from pin 56B of the light switch; and the high beam wire is just white, coming from pin 56A.
    Sep 2004
    Argyle Texas
    Thanks, that's what I needed to know!
    04 R1150RT
    RK Ryder
    London, Ontario
    Quote Originally Posted by skibum69 View Post
    +1
    Having separate switches for the auxiliary lights has never been a problem for me. I've never had a problem with law enforcers but if I was ever in conflict with local laws, the separate switches would make complying easy.
    Paul F. Ruffell
    Niagara Riders & Knights of the Roundel #333
    Sep 2004
    Argyle Texas
    Lightbulb
    +1
    That's a good idea too.
    04 R1150RT
    Sep 2004
    Argyle Texas
    I'm still working on the lights. I installed them on the fork screws that hold the front fender in place. These screws are on each side of the forks but I would really like to install them under the fairing section that is forward of and below the oil cooler, just above the front fender. I would have to drill two holes up from the underside of the fairing. I'm concerned about drilling holes into the plastic that could cause the plastic to crack in the future. Has anyone drilled through the plastic fairing to mount items and had any problems? I believe I have seen pictures of lights mounted in this area.
    I'm also still working on the wiring. I found the wires inside the compartment where the high beam bulb is but I cant connect them because that area is sealed under normal conditions. I'm reluctant to unwrap the wiring bundles in the fairing in hopes of finding the right wire. Right now I have them wired to the battery but i have to remember to turn them off or they will drain the battery leaving me stranded. The manufacturer recommends wiring the lights to a switched power source such as the license plate wire. I already have my Third Eye Design helmet light connected to this wire. Would another accessory tapped into the same tail light wire cause any problems?
    04 R1150RT
    RK Ryder
    London, Ontario
    Quote Originally Posted by scootrp125x View Post
    My lights were originally located under the oil cooler, attached to a bracket (since sold). For me the triangle was not wide enough (in my opinion) and on occasion, the lights would bump against the front fender leaving marks on the fender's paint.
    Paul F. Ruffell
  1. 2004 R1150RT Fog Lights Blowing Fuse
    By grendellion in forum Oilheads
    Last Post: 12-14-2016, 01:59 AM
  2. Wiring Denali lights on R1150rs
    By milump in forum Oilheads
    Last Post: 06-12-2012, 01:51 AM
  3. Denali Lights - Feedback Wanted
    By mvscorpio in forum Gear
    Last Post: 04-11-2012, 09:39 AM
  4. Denali d2 lights
    By booger man in forum Wedge K-bikes
    Last Post: 01-25-2012, 01:57 AM
  5. Denali LED Driving/Fog Lights
    By grahamm in forum Gear
    Last Post: 02-20-2010, 12:59 AM
