Results 1 to 12 of 12
Thread: Nube error - Messed up on alternator belt tensioning
    Jun 2017
    Prescott, AZ
    I replaced the HES this past week on my 2010 R1100RS. I've had the bike a couple years and decided to put a new belt on as well since I wasn't sure when it had last been replaced (currently 68,000 miles). Read the Clymer and watched video to properly adjust the tension on the belt and got to it. UNFORTUNATELY, I didn't remember (or never realized) that the reverse on my torque wrench wasn't for measuring torque. I thought I'd learned my lessons about if it feels wrong, it probably is. Regardless, I torqued down way too hard and cracked the tensioner nut (Clymer calls it an idler I think). Does anyone know where I can find one of these?
    Left Coast Rider
    Nov 2011
    I'm going to assume you mean 2001 R1100RS. I believe the part # is 12 31 7 677 914.
    Available from your local BMW dealer or online from MAX BMW.
    https://shop.maxbmw.com/fiche/Diagra...6&rnd=07242017
    Diagram # 12_0767 in Section 12 - Engine Electrics.
    Jun 2017
    Prescott, AZ
    Thanks for that. Will bookmark this page for future use. Off to get a reversible torque wrench...
    Quote Originally Posted by mhallman View Post
    You do not need to overthink this. It is just a rubber drive belt. If you tighten the belt until you are able to twist it 90 degrees at the midpoint between the pulleys you will be just fine. That is not too tight. If it is too loose it will squeak on engine startup. If it were too tight the part that would be damaged is the front bearing in the alternator. I used this technique on my R1150R. That alternator was still alternating at 177,000 miles when I sold the bike. I use this technique on Voni's R1100RS and the alternator is still OK at 412,000 miles. The commutator is a bit grooved but the bearing is fine.
    Jun 2017
    Prescott, AZ
    Thanks Paul. As someone trying to "learn-as-you-go", it's easy to overthink things. It's fun to work on the bike, but not when you end up fixing one thing but breaking another...
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    I have an extra, PM me.
    Ufda happens..........
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    I have used the method of belt tensioning that Paul mentioned for many years as well.
    This 90 degree tension check is actually spot on when you check it with a torque wrench..YMMV
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, ‘17 R1200RT
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    They do make belt tension gauges that are easy to use. Universal application.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Quote Originally Posted by dieselyoda View Post
    If you know what the tension spec is supposed to be? Or is it a universal value?
    Feb 2008
    Or you can torque to spec from the front with the BMW special tool
    https://shop.maxbmw.com/fiche/PartsD...T_12%203%20551
    per service bulletin 12 001 02
    or make your own.
    Mar 2013
    There are a bunch of them out there based on the belt only. I recently saw Gates used a piece of tape. You applied the tape to the belt. You tightened the belt and when the tape broke, that was the perfect tension for the belt.
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    From the shop manual, it's 8 Nm.
  1. alternator belt
    By samo in forum Oilheads
    Last Post: 08-16-2014, 01:50 PM
  2. Alternator Belt
    By 110164 in forum Oilheads
    Last Post: 03-11-2009, 02:17 AM
  3. Alternator belt on 1999 rt
    By bcusack in forum Oilheads
    Last Post: 12-23-2008, 02:33 AM
  4. alternator belt
    By 106179 in forum Oilheads
    Last Post: 10-08-2008, 11:21 PM
  5. Alternator Belt kit
    By lazygoodan in forum Oilheads
    Last Post: 09-05-2003, 11:28 AM
