Results 1 to 6 of 6
Thread: Innovv k2 wiring help
    I'm an "electrical" novice and would really appreciate some pro advice for installation. In addition to usual red/black to red/black, the yellow wire must connect to a switched device/circuit, so the unit knows when the bike is on/off. On a 2018 GSA, how would I go about this without blowing up the neighborhood? Thank you.
    Hugh
    Registered User bicyclenut's Avatar
    Jul 2016
    Sugar Grove, IL
    Without adding something like a Hex EZCan or addition fuse block, etc. probably best to go off the license plate light or taillamp light as these would turn on with ignition on. Probably also located in area under seat where you would be placing the DVR.
    The Innovv has a relay box that switches the system on and draws power from the bike when it detects power from the yellow wire, it doesn’t use power from this but uses it to turn on relay.
    2010 BMW R1200RT
    2014 BMW C650T
    MOA # 208387
    Mansfield,MA
    Welcome to the forum!
    I like the parking light concept. Here a thread with some info-
    https://forums.bmwmoa.org/showthread...for-fuse-block
    Good luck.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Aug 2018
    Fargo, ND
    If you have Powerlet sockets they are on with power up and off a few seconds after the bike is shut down.
    From the only real Fargo, ND!
    Registered User crna59's Avatar
    Apr 2017
    Issaquah, WA
    I bought a Canbus connector that I could connect directly to. Works like a charm!!
    Bruce A. Brown #212072
    MSF 2-wheel Instructor
    H-D Riding Academy Instructor
    S/TEP 3-wheel Instructor
    Thanks all. Reminder that all the lights on the 2018 GSA are LED. Motorrad tech determined that getting enough bang to trigger the K2 requires patching into the fuse for an LED - in this case the headlight fuse. So far the K2 and bike are all happy, and so am I.
  1. Innovv K1 Moto Dash Camera Review
    By ppalac in forum Gear
    Last Post: 04-06-2016, 04:40 PM
  2. Replies: 11
    Last Post: 08-28-2011, 01:17 PM
  3. Wiring Help
    By greenwald in forum Gear
    Last Post: 03-07-2009, 01:32 AM
  4. K75 wiring
    By cayuse60 in forum Flying Brick K-bikes
    Last Post: 03-15-2008, 11:34 PM
