Results 1 to 15 of 25
Thread: F700 vis F750
    gig harborr ,wa
    F700 vis F750
    What improvements does the 750 have over the 700? Not counting the engine size.
    Apr 2015
    Southwestern Connecticut
    Quote Originally Posted by EUGENE View Post
    Itís porkier.
    2002 R1150R
    2016 BMW F700GS
    Registered User markw62@verizon.net's Avatar
    Jan 2016
    Chesapeake, VA
    1. approx. 5 more horsepower
    2. loads more tech (i.e., addition of Wonder Wheel, Enduro mode, cruise control, TFT display...and all that it brings.)
    just to name a few...and of course, it's porkier.
    Registered User ackme's Avatar
    Mar 2019
    Parker, CO
    I dont have experience with the F700 to make a direct comparison. But hey, its the internet so why should that stop me from commenting!
    I came from pretty far down-market, Honda NC700x manual, to the F750. It was a revelation. I really feel like a better rider on this bike. There is just so much more control in every facet - acceleration, braking, handling. This bike is just so much more refined. And if what I read about the re-design from F700 to F750 is at all accurate I would have to think the riding experience is significantly different as well.
    I will add that my experience with F750 is all on road. I could not say how it stacks up when compared to off-road. Riding both the F750 and F850, I just felt more comfortable on the 750. Clearly the difference between the 19" front and the 21". I'm 6' with a 33" inseam so the 850 did not feel too big,, it was really the riding experience that liked better on the 750
    The power is fine for me although I do just leave it in dynamic 99% of the time. If the F750 has 5hp more than the F700 it should feel pretty similar as far as that goes.
    The TFT screen is great. The location of the Nav mount is stupid. The interface with phone/TFT/helmet is problematic but not awful. I find the seat comfortable. The ergos are good for all day riding for me.
    ...and it is porkier than the NC750x too.
    ackme
    gig harborr ,wa
    Ackme, does your 750 have dynamic ESA OR not?
    Mar 2019
    Parker, CO
    Yes. Should have mentioned that. It was a pretty loaded model off the floor - the premium packages, comfort seat and center stand. So it has all of the electronic technowhizz-bangery. A better rider than I might find all of that intrusive at times but i suspect that is what makes it feel so great to me.
    Registered User crna59's Avatar
    Apr 2017
    Issaquah, WA
    Yes.... it's porkier..... with a higher center of gravity (top heavy). They moved the gas tank from under the seat.
    Bruce A. Brown #212072
    MSF 2-wheel Instructor
    H-D Riding Academy Instructor
    S/TEP 3-wheel Instructor
    Mar 2019
    Parker, CO
    FWIW, the Motorrad engineers claim the re-designed chassis with tank back up top has improved the center of gravity and overall handling. Seems counter-intuitive but I cant imagine BMW making that change and the claim without good reason.
    Quote Originally Posted by ackme View Post
    Can you provide a link to that claim by the engineers? Iíd like to see that discussion.
    I was told by a knowledgeable bmw salesperson that the tank was moved forward to improve handling (by concentrating fuel weight between the front and rear wheels, rather than over the rear wheel), but that as a consequence the cg was higher.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    For far too many of us the solution to a high center of gravity rests not in the hands of engineers, but rather in the hands of Jenny Craig.
    Kevin Huddy
    Mar 2019
    Parker, CO
    Quote Originally Posted by vark View Post
    I think this is the press release from Nov.2017. I guess you if you parse the language they say the CoG is "improved" not "lower" so the F700/800 might be actually lower but in the view of BMW the F750/850 has a better result.
    "New steel bridge frame in monocoque construction, optimised
    suspension geometry and new fuel tank position.
    The bridge frame of the new GS models in the F series is made of deepdrawn, welded components. It integrates the 2-cylinder in-line engine as a cosupporting element and offers benefits in terms of torsional rigidity and
    robustness. The fuel tank has been placed in the classic position between the
    seat bench and the steering head, for optimised packaging and an improved
    centre of gravity."
    https://www.press.bmwgroup.com/globa...75427EN/397328
    centre of gravity."
    Thanks.
    CoG is measured in combination fore/aft, laterally, and vertically. Itís possible to ďimproveĒ it without actually lowering it.
    That description in the press release above is consistent with what was described to me at the dealership, i.e. the tank was moved forward to improve the overall balance of the bike to benefit handling.
    I suspect BMW would have claimed they had lowered the CoG if in fact they had done so. That doesnít mean there is anything wrong with what they did and in fact I donít doubt their claim that CoG is improved overall. I just remain skeptical that it is lower than on the F700.
    Mar 2019
    Parker, CO
    I think both of you are 100% correct. This guy's opinion is that the higher CoG on the F750 is an improvment -
    "A big difference between the 700 was locating the slightly bigger 15-litre tank back up front. This raises the mass of the bike, but as mentioned in the 700 review, too low a CoG can make a bike hard to turn easily. and on the dirt, including loose hairpins, the 750 didnít exhibit the resistance I felt in the 700."
    "https://adventure-motorcycling.com/2019/11/20/bmw-f750gs-in-morocco-%e2%80%a2-1200-km-review/
    That makes sense.
    Another point I recall mentioned at the dealer was the F700 with tank under seat is very nicely balanced when ridden as a bare bike. But loaded up with panniers and top case or two-up it tends to be slightly rear-biased in weight distribution.
    So moving the tank forward on the 750 may be a slight improvement for those who ride heavily laden. I wonder how many of us would be able to notice the difference, though?
    Jul 2019
    Orlando, FL
    Did not have the pleasure of riding a 700.... but this 850 is top heavy... and I know that I have the GSA, but even with a nearly empty tank this sucker is top heavy...
    Ride safe!
    Wachuko
    2019 BMW F 850 GS Adventure
  1. F750 Steering Dampener
    By weschmann in forum F-Twins
    Last Post: 04-14-2019, 12:15 PM
  2. Replies: 7
    Last Post: 01-31-2019, 06:38 PM
  3. F700 gs
    Last Post: 12-29-2013, 06:01 PM
  4. Looking for information on BMW F750
    By palica in forum Airheads
    Last Post: 08-28-2012, 08:38 PM
