Results 1 to 4 of 4
Thread: Headlight Bulb/NO Markings
Hybrid View
    13278
    Near Lynchburg, VA
    í57 R60.
    Previous owner installed this bulb and appropriate reflector. Bulb has no markings. Iím guessing that it is 6v because it works and during the Daytime, it is bright. Wasnít impressed during a night test. Although it may be a decades ahead upgrade.
    Just wanted to get spare bulb. I call it an H4 base.
    Anyone recognize this 6v bulb and know where they buy them ? (If it is 6v)
    Charlie
    Photos wonít load correctly, but the bulb itself looks like every 60/55 black tipped H4 Iíve ever used.
    Central Ohio
    Google finds: https://www.google.com/search?newwin...4dUDCAs&uact=5
    Apparently available in 35W/35W and 55W/60W versions. If you have the 35W version, it probably is not very impressive, but I'm not at all sure your switch and wiring can handle the 55W/60W bulb without melting.
    Larry
    2006 R1200RT
    13278
    Near Lynchburg, VA
    Thanks Ikraus, very handy info.
    Charlie
    '99 '03 '06 National Co-Rally Chair Friedle's Avatar
    Poughkeepsie, NY
    Quote Originally Posted by lkraus View Post
    I have always used the 35W with the 6 volt systems and the 55W with the 12 volt system. Same bulb base pattern for the /2 headlight plug as for the /5 bulb base plug.
    Friedle
    Ride fast safely
  1. Headlight bulb
    By bdfbeemer in forum Wetheads
    Last Post: 09-11-2015, 06:05 AM
  2. anyone try this headlight bulb?
    By jmolsberg in forum Airheads
    Last Post: 03-18-2011, 04:23 PM
  3. Which headlight bulb?
    By barry5k in forum Hexheads/Camheads
    Last Post: 10-12-2009, 11:35 PM
  4. Bulb Issues (Headlight)
    By pedrocasper in forum Airheads
    Last Post: 06-21-2008, 03:17 AM
  5. Headlight Bulb
    By SEMUTA in forum Airheads
    Last Post: 08-02-2007, 05:49 AM
