Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
Thread: Disaarm the side stand interlock
    Question Disaarm the side stand interlock
    I want to eliminate the ignition lock out when the side stand is down. A pain in the ass for start up. I believe its just a matter of joining the two wires at the side stand witch. Just need to be certain.
    Appreciate some guidance.
    jimmy armour
    Jul 2009
    Lucknow ontario canada
    sidestand switch
    Hello, you dont mention what year your bike is in my case a 2000 r1100rt it was just the two wires,I belive the later bikes have 3 or more wires and relays so is not as simple ,I removed switch assy as well but not needed ,I didnt like the idea of a cut out switch that could cut out on the road so just remember to put the stand back up before moving off ,hope this assists ,Jimmy
    Quote Originally Posted by JALAIMO146577 View Post
    I want to eliminate the ignition lock out when the side stand is down. A pain in the ass for start up...
    What model bike is this? Doesn’t neutral disable the ignition lockout?
    Mar 2019
    Fort Wayne, IN
    If it’s as easy as twisting two wires together than I’m doing that posthaste. Nothing irks me more about my R1100RS than no running with the side stand down!
    Denny
    Quote Originally Posted by vark View Post
    It does on my R1150R. Not so on Voni's R1100RS.
    Jan 2016
    Central Illinois
    Side Stand Switch
    I a world of annoying things this is very low on my list. The times I tried to start the bike with Side stand Down and was annoyed or irritated because bike would not start is also a time when I probably should have been getting my wits together and not be riding.
    Usually when I go for a ride I start bike up roll it backward out of garage than down hill until I clear cars in driveway, it’s not fun rolling backwards and finding out your side stand is down.
    I have a friend that started his bike once took off and while making the first left turn he found out his side stand was down he did not get hurt much, the bike was not hurt but it was a pain to pick it up and several friends saw his misadventure which caused some mental pain.
    It may be annoying when bike won’t start because of safety switch but it is not painful.
    Quote Originally Posted by 179212 View Post
    Voni was riding with a friend of ours on the double-letter back roads of Missouri several years ago. They had stopped for some reason - gas, potty stop, whatever. Then they resumed their ride and on the first left hand sweeper Debbie, who had left her sidestand down, had the stand hit the pavement, lift the rear wheel, and spin her leftward across the opposite lane, through the ditch, and into the front yard where the fire department and medics were having their annual picnic. The bad news was she crashed. The good news was that the medic response time was seconds instead of minutes.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Think long and hard before bypassing this important safety feature.
    Ufda happens..........
    I had my mechanic disable mine through a switch under the fairing, he unplugged it. Said the wire work around wasn't the best way to disable the feature. On my 2012 r1200GS, it's under the left front area in front of the tank. Took him 5 minutes to remove the plastic and disconnect it.
    Yes, it's a safety feature, but I preferred not to have to deal with an arrant circuit leaving me stranded in the middle of nowhere on the Alcan, BC/Yukon or Ak.
    The lion does not even bother to turn his head when he hears the small dog barking.
    https://www.youtube.com/user/azqkr
    Registered User K7GLE's Avatar
    Apr 2016
    Seattle
    From a convenience standpoint I'd rather the bike would start on the side stand. Then I think of the number of times I rode my airhead off a ferry with the stand down...never dumped it, but came very close a couple of times. The boat workers are pretty good at noticing and pointing this out to riders as they leave the boats. (The ferries are a hotspot for this problem because we tend to sit on the upright bikes and let them idle during the minute or two the boat is getting snugged into the dock. It's easy to leave the stand down for stability "just in case" the boat shoves sideways during this maneuver. Bikes exit first, and no one wants to hold up traffic, so when workers finally drop the rope it's easy to forget the stand is down. )
    - Glenn
    2000 R1100RT (current)
    1982 R100RT (traded)
    1970 BSA A65T, 1969 Honda CB350, 1967 Honda CB160 all fondly remembered
    Apr 2006
    Nibley, UT USA
    Quote Originally Posted by brownie0486 View Post
    I am surprised that a professional mechanic would do that, given the liability issue it creates for the mechanic and the business in which he is employed. IMHO better he should show you the location of the connector and how to access it, then leave it connected so you still have that safety feature in effect for the 99.99999% of the time that it is functioning correctly—especially when it only takes 5 minutes to disable.
    Best,
    DeVern
    DGerber
    1983 R80ST — 1984 R80 G/S-PD — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT — 2018 R1200GS
    Quote Originally Posted by GTRider View Post
    Best,
    DeVern
    I agree.
    My current bike (not a BMW) will start with the sidestand down as long as it’s in neutral. If I shift into gear with the sidestand down, the engine cuts out. I would never disable this safety feature.
    I figured this was a safety requirement on all modern bikes - - I am surprised to learn that it isn’t.
    Best,
    DeVern
    What liability? I'd have to sue him for him to suffer any repercussions from meeting my request to disconnect it. We have a better relationship than that, he knows I have enough integrity to not put him on the hook for something I asked him to specifically perform. Would he do the same for others, no clue, don't care.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    There can just about always be liability when a jury says there is. You have no real idea how you might react were you badly injured, say made a quadriplegic, and driven into bankruptcy by loss of ability to work, medical bills and needing lifetime around the clock care. Nor can you predict how your heirs would react were you killed. There was a fellow here in Montana making side stands for airheads that did not retract automatically by spring pressure when the weight was taken off the stand. The stands were also much easier to deploy than the stock stands. A fellow bought one, and remember it was sold as not auto retracting; the buyer got exactly what he asked for. He forgot to raise the side stand, wrecked his bike and died as a result. The late rider's widow sued the maker of the side stand and won, thus driving the maker into bankruptcy. I'd bet a $100 to a donut that the rider would have sworn neither he nor his wife would never sue the maker if he was injured as a result of using the side stand.
    Kevin Huddy
  1. Replies: 32
    Last Post: 11-09-2015, 02:53 AM
  2. 1994 K75, center stand, side stand lube
    By ted in forum Flying Brick K-bikes
    Last Post: 10-13-2012, 09:59 AM
  3. Side Stand or Center Stand
    By groeger in forum Oilheads
    Last Post: 11-19-2006, 10:29 PM
