Results 1 to 12 of 12
Thread: How to replace the battery in keyless ride FOB? 2017 RT
    Registered User ajaxthegreater's Avatar
    Jun 2013
    Highlands Ranch, CO
    Read the instructions and it says push "up" on the cover to expose the battery. Tried and mine doesn't budge in any direction. Is there some trick to this?
    Bill in Highlands Ranch, CO
    2012 R1200RT
    Registered User kioolt's Avatar
    Maryland
    Tried mine too. Couldn't get it to budge. Then I looked on YouTube. https://www.youtube.com/watch?v=TIbdzC5rqGA
    2004 R1150RT 186,800 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 422,400 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Jun 2013
    Highlands Ranch, CO
    Quote Originally Posted by kioolt View Post
    So just push really hard...it worked. Thx.
    2012 R1200RT
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Brute force and ignorance are called for.
    Kevin Huddy
    Knight-Errant 1957mpd's Avatar
    Feb 2018
    Las Cruces,NM
    Naval Engineering....
    Ditto. Just went through this drill when the yellow triangle lit up. As a Navy Master Chief once told me, "If force doesn't work you're not using enough." I also wound up using a screwdriver blade to help nudge it free.
    "Soló el que ensaya lo absurdo es capaz de conquistar lo imposible." Miguel de Unamuno 1905
    Mark - Las Cruces, NM - '17 R1200 GSA
    Apr 2006
    Nibley, UT USA
    Quote Originally Posted by 1957mpd View Post
    I believe it’s the Brits who maintain that “Any tool can be a hammer, but a screwdriver makes the best chisel.” Glad to see this thread and the video as I believe I have a fob battery slowly dying.
    Best,
    DeVern
    DGerber
    1983 R80ST — 1984 R80 G/S-PD — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT — 2018 R1200GS
    Mar 2011
    socal
    I use the sharp blade of my best pocket knife to pry mine open
    It’s the o-ring that holds it fast
    Biggest tip I have is to use quality batteries either Panasonic or Duracell,buy a couple spares. The cheap Chinese junk only lasts about 60 days
    Jim
    Jun 2013
    Highlands Ranch, CO
    I mistakenly thought the little key battery symbol was saying my fob battery was at half strength. Luckily I checked the manual and it said it means replace it.
    2012 R1200RT
    Quote Originally Posted by ajaxthegreater View Post
    Yeah, replace the battery, or the damn thing will eventually NOT start. As our cell site maintenance techs say, “If it won’t work, get a bigger hammer!”
    Jul 2007
    Big Sky Country
    Both Annie and I recently got a symbol on our dashes of a key with a question mark. Turnsout that means the bike cannot detect the fob. It happened to me first when we were riding and the bike continued to run normally, but when we stopped it would not restart. Changed batteries a few times but it did not solve the problem. I restarted it by putting the fob under the rear fender near the sensor. We happened to be in Missoula near Big Sky BMW and they checked it and it was showing two different key codes. They cleared them and repaired the fob and all was well. It nexted happened when we were in Colorado and would come and go on both bikes. Annie reasoned out that we had both recently switched to Cardo Packtalk Bold communicators and that we both wear our fobs on a lanyard around our necks. Perhaps too close she thought even though we had worn them there for two years while using Sena 20Ss. I, of course, poo-pooed her idea. She moved her fob to her right pants pocket and the problem ceased and has not reoccured in a couple thousand miles. I quietly moved mine to my pants pocket and have not had an issue since.
    The Packtalk is not Bluetooth and the Mesh technology it uses must interfer with the bike to fob signal just enough to confuse the bike.
    Kevin Huddy
    Kevin, I know you know you are best off when you listen to Annie's intuition. It saves a lot of time usually.
    Jul 2007
    Big Sky Country
    Where is the fun in that?
    Kevin Huddy
  1. Keyless ride key fob?
    By PoorUB in forum Wetheads
    Last Post: 08-25-2019, 08:55 PM
  2. Tankbag for Keyless Ride
    By brookscooper in forum Wetheads
    Last Post: 07-05-2019, 02:55 PM
  3. Keyless ride
    By DONPRICE in forum Wetheads
    Last Post: 03-27-2017, 10:20 PM
  4. GIVI XS307 tankbag for 2017 RT keyless
    Last Post: 03-13-2017, 02:08 PM
  5. Replies: 18
    Last Post: 11-30-2014, 01:47 AM
