Results 1 to 7 of 7
Thread: 1990 k 75 s rear shock?
    not lost til out of gas chasmrider's Avatar
    Jan 2013
    troutdale,or
    hi all, I recently acquired a 1990 K 75 S with 80,000 miles. it runs and rides good, but..... I think I need a new rear shock. I would like to hear what you are running, also wondering if I should get a " good " used on ebay, or buy new. I have bought several shocks from Ted Porter for other bikes, so probably would buy new from Ted. any thoughts? Chuck
    don't know where I'm going, but I'm making good time. 1978 R 100 S, 1990 R 100 GSPD, 2005 R 1200 GS
    I recommend the Progressive 412-4015B.
    Tuned well for the K75S.
    Quick and easy preload adjustment for changing loads (which means you will actually use it).
    Great bang for the buck.
    When they start to wear out, I can put a NEW damper (using the existing spring) in them for less than the cost of a rebuild on a rebuildable shock or buy an entire new unit for close to the price of a rebuild (which usually is only a few seals) that they charge a few hundred for.
    https://www.ebay.com/itm/Progressive...IAAOSwYy5dJKFc
    Progressive also offers a shorter (1/2- 3/4") shock that has a slightly softer spring 412-4016B for a similar price.
    Oct 2015
    alexandria, va
    Don't get a used shock. They are probably as dead as the one on your bike now. Call Ted's Beemer Shop.... They will steer you through the variety of new shock options. It is not just a shock, it is also about getting a spring that is matched to your weight and riding load.
    Marshall
    92 K75s, 94 K75s, 96 K1100RS (caretaker), 09 K1300s
    Ted Porter Plus 2
    Go with Ted, he is straight up and will be the best with customer service.
    Jan 2013
    troutdale,or
    thanks, the progressive sounds good.
    Nick Kennedy
    Telluride Colorado
    I put that progressive 412 on my 1990 K75RT a couple of years back
    Very happy with it
    Changed for the better, how that bike rides and feels.
    Apr 2013
    Southern California USA
    Quote Originally Posted by 69zeff65 View Post
    ^+3
  1. 1990 K75S Factory rear shock or aftermarket?
    By scottishsg in forum Flying Brick K-bikes
    Last Post: 09-17-2014, 04:39 AM
  2. 1990 R100RT oil leaking from rear seal
    By 1der in forum Airheads
    Last Post: 06-28-2013, 03:22 AM
  3. Replies: 3
    Last Post: 12-21-2012, 04:24 AM
  4. WTT: Standard Rear Shock for Low Rear Shock
    By shropdog in forum F-Twins
    Last Post: 10-28-2012, 12:58 PM
  5. Rear Shock Sticker shock
    By rsrhouse_123 in forum Flying Brick K-bikes
    Last Post: 01-05-2009, 02:10 PM
