Results 1 to 15 of 15
Thread: R1100RT battery issues?
    Feb 2015
    Davenport, IA
    After a couple months of not riding yesterday the bike was hesitant to crank so I put it on the charger and within a few minutes it started and was fine the rest of the day. I left the charger on overnight and this morning it started when I pulled it out of the garage and parked it for an hour in the driveway. When I went to start it again something peculiar happened. The dash lit up fine but as soon as I hit the starter I heard a click and the dash went dim, not out just dim. So I hooked the charger back up and after a while it indicated charged the lights are still dim and I hear a faint clicking when I try to start it. I get it that the clicking is a sign of not enough juice but am puzzled by the sudden failure and not being able to charge the battery from one day to the next.
    I have to admit that the battery is about ten years old so hopefully that's my problem but I'm used to car batteries dying slowly. I guess one question I have is if the sudden failure is typical.
    Mansfield,MA
    Well, you are about double the “best” general battery life. You need a battery and chances are you will be good to go.
    Someone will chime in on battery suggestions.
    I will move this to the Oilhead section later.
    Mod Squad
    2009 F800GS 1994 TW200
    Feb 2015
    Davenport, IA
    A new battery would be great. Just was surprised it dying suddenly but I guess after ten years I am not surprised. Just checked on it again. Charger is lit up green, dash lights still dim and no juice for the starter with the charger hooked up or unplugged.
    Mansfield,MA
    I have never heard of a battery lasting that long. These batteries seem to be rather iffy.
    You are probably seeing a connection of the electrolyte which has no real power behind it.
    One of my experiences-
    https://forums.bmwmoa.org/showthread...died-yesterday
    Mod Squad
    Feb 2015
    Davenport, IA
    I'll get the battery replaced and report back. Thanks for the input.
    Mansfield,MA
    Sounds good
    Mod Squad
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by ddincer View Post
    My bet is you've got a short between cells in the battery. Only one thing to do - replace it.
    You just had a cell connector internal to the battery crack and/or break. You may read normal voltage but it can't flow any significant current. This is the typical failure mode for AGM and Gel batteries. They cram a lot of plates in a small space and they are mechanically fragile.
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    If ten years out of a battery isn't good enough, you can always take two months to determine you have a bad battery and read this: https://forums.bmwmoa.org/showthread...-Battery-Redux
    I live in a place where if a battery lasts 4 years, I go buy a lottery ticket............Haven't won the lottery yet.
    Believe it or not, almost universally, every battery manufacturer will say hot-cold, charge-discharge cycles have less influence on battery life than previously thought and harmonic resonance is the most considerable factor, hence, new vehicles are wrapped in blankets and battery boxes are on some sort of rubber or silicone suspension.
    I'm not sure I entirely agree but when they can make a GRP 24 with the same CCA as a D4, I'm thinking technology is pushing the limits of a bike made +20 years ago.
    And, a good battery is less expensive than a good tire, just one of them.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Feb 2015
    Davenport, IA
    New battery did the trick. Interestingly the old battery still measured 12.6 volts but obviously not able to deliver the amps.
    I should be good for another 10 years (just kidding).
    Mansfield,MA
    You might want to have that old battery bronzed
    Nice simple fix. These bikes ask a lot of small batteries.
    Mod Squad
    Indeed. My K75 which brings 250cc to compression at a time came with a 30 amp hour (ah) battery. The "little" one which would also fit was a 19ah battery. But Voni's F800 came with a 14ah battery. And our G310GS bikes come with a (gasp) 9ah battery.
    Mansfield,MA
    Yeah, gives new meaning to the term "starting battery".
    I have never had any worries "pop" starting a chain-drive bike........so there is a chance with a low battery.
    Mod Squad
    Albuquerque, NM
    Yes it is. Everybody's different, but every battery failure I've had has been sudden ... that is, I've never been able to detect one failing slowly.
    Kent Christensen
    21482
    ... but I'm used to car batteries dying slowly. I guess one question I have is if the sudden failure is typical.
    See post #8, this thread.
  1. 2000 R1100RT final drive issues
    By littledog in forum Oilheads
    Last Post: 04-03-2014, 08:01 PM
  2. 1997 R1100RT Electrical Issues
    By 97RT in forum Oilheads
    Last Post: 07-07-2013, 01:51 AM
  3. ABS Startup Issues 2000 r1100rt
    By deweybr1920 in forum Oilheads
    Last Post: 08-18-2012, 12:38 AM
  4. Battery/Start issues
    By corynott in forum Oilheads
    Last Post: 07-07-2011, 04:10 AM
  5. 98 R1100RT Electric issues
    By OHIOMASTERPLUMBER in forum Oilheads
    Last Post: 08-02-2010, 11:07 PM
