Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Thread: Change in recommended oil weight (Yay an oil thread!)
  1. #31
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    Either way it sounds like you need a top end rebuild. Well, maybe not YOU but your bike.
    For BMW using up to 1L of oil per 1000km is consider normal.
    Since I use 0.5l / 10000km
    I'm well within their specs
    Although the recommended oil viscosity is now 15W50
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
  2. #32
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    I certainly would not tolerate using a liter of oil every 600 miles.
    Kevin Huddy
  3. #33
    Registered User pappy35's Avatar
    Nov 2017
    Collierville, TN
    I carefully track my oil consumption and so far after about 13,000 miles since I bought it I'm burning 6-11 ounces per 1000 miles. I'm good with that.
    '13 R1200RT 90th Anniversary Edition
  4. #34
    i should be out riding! wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    Quote Originally Posted by pappy35 View Post
    as do i....my 13RT used about the same up to about 18000-19000 miles...after that consumption dropped off dramatically...now at better than 107000miles it uses very near zero oil between changes every 6000 miles...Mobil 1, 15w50...
    ~wyman~
    2013 BMW R1200RT - Sassy - Fluid Grey Metallic
  5. #35
    Nov 2017
    Collierville, TN
    Quote Originally Posted by wyman.winn View Post
    Mine's just under 19,000 now. Runs like a nose. 8-)
  6. #36
    Left Coast Rider
    Quote Originally Posted by Dann View Post
    Well within their specs when they want to deny warranty for excessive oil consumption. Car manufacturers use the same spec. If their cars performed at this level there would be hell to pay and a permanent blue haze over every city.
    As many others here have noted, my 1100 also used virtually zero oil touring at 120 km/h+ speeds in 35-40C temps with Mobil 1 15W-50. My wedge 4 cylinder is the same with Castrol Power One 10W-40.
  7. #37
    If the marketing department portrayed as "normal" the same horsepucky that the lawyers and cost accountants used they would sell a lot fewer vehicles. And if the engine design engineers thought that consumption like that was normal they would all resign and go back to school. Companies as big as BMW think with multiple brains and speak out of both sides of multiple mouths. So far none of the 31 BMWs we have owned ever used oil like that. None. Not even the engines over 300,000 or 175,000 miles.
  8. #38
    Dec 2013
    Laval, QC, Canada
    I agree. 1l /1,000km is not acceptable.
    By stating this they can turn down any complaints about oil consumption.
    At 0.5l /10,000km , I'm fine with that.
    Daniel
  9. #39
    Just to set the stage, BMW recommends an oil change every 6,000 miles = 10,000 km
    So at 1 liter per 1,000 km that would be 10 liters between oil changes. Oh sure, that's OK
    But I do agree that 1/2 liter in 6,000 miles or 10,000 kilometers would not be too bad.
  1. Recommended oil weight F650CS
    By letchworth in forum Thumpers - F & G bikes
    Last Post: 08-15-2009, 03:25 PM
  2. 2009 Get-in-Shape/Weight Loss thread
    By knary in forum Campfire
    Last Post: 06-25-2009, 12:55 PM
  3. 2008 Get-in-Shape/Weight Loss thread
    Last Post: 12-15-2008, 02:46 AM
