Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Thread: Tires losing 4 PSI per day is normal?
    Team,
    My 2010 RT with Road 5 tires lose about 1 PSI per day on the front wheel and 4 PSI on the back wheel per day. I check my tires every day but wasn't expecting to have to inflate them every day. These are new tires and have no visible punctures. I'm told by other motorcycle friends and one motorcycle mechanic that "sport tires" will lose air very quickly.
    What gives?
    Thanks,
    Brent
    Aug 2014
    Lakeland,FL
    Not normal in my world with any tire.
    Jan 2016
    Central Illinois
    Tires
    Valve Stem?
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    It's not normal.
    Maybe leaking at the valve cores or tire beads.
    Lee
    2016 R1200RS
    MOA # 30878
    Jul 2008
    Central PA
    Quote Originally Posted by 179212 View Post
    Valve Stem?
    That would be my choice.......
    Cave contents: 16 R12RS, 13 Toyota Tacoma, 03 Simplicity Legacy, 97 Stihl FS75, Dewalt DW625 & SawStop PCS175
    1) My expectations are never low enough & 2) Incompetence is infinite ........David Brooks
    Mansfield,MA
    Checking your tires every day is/will be tough on the cores in the valve stems. I like a “trigger-sprayer” with a mix of water and dishwashing soap to test with. Watch for “foaming” or a slow lazy bubble.
    Mod Squad
    2009 F800GS 1994 TW200
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Brent,
    Start by removing the valve stem caps and spraying the stems with Windex. Bubbles coming out end = loose or bad valve core. Bubbles coming out around base = bad stem.
    If no bubbles from stem, try spraying around the bead (where the tire meets the rim). If you have bubbles there, someone didn't clean the rim adaquately when the tire was mounted.
    Or
    Some tires have mold "whiskers" that are very close to the bead that under some circumstances, during mounting, can be stretched between the bead and the rim, causing a leak.
    Edit: Damn, I get a phone call in the middle of answering you and four people respond!
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Quote Originally Posted by brentseay@gmail.com View Post
    Brent
    They are wrong. Modern tires of any variety do not lose air very quickly if the valve stem and core are sound and the rim is clean when the tire is mounted.
    I find that with PR4 tires on an R1100RS and R1150R I might need to add a pound or two every month.
    Had a valve stem not fully tightened that was discovered to be the culprit of 2-3#'s a day. I'd start there as others have suggested/.
    The lion does not even bother to turn his head when he hears the small dog barking.
    https://www.youtube.com/user/azqkr
    Registered User terek's Avatar
    Oct 2019
    S.F Bay Area
    Try mixing 25/75 concentrated soap to water.
    I had similar PSI lose a week ago, 11 PSI a day. The air lose turn out to be a small wire that punctured the inner edge of the tire groves. There were no tiny bubbles, but a single very slow expanding bubble (1mm every 2 sec).
    Aug 2018
    Fargo, ND
    The OEM Michelins that were on my RT were tight, I rarely added air. The tires on my Yamaha R1 lose maybe 1 pound every two weeks.
    A pound a day? Nope, not buying that.
    On the other hand, how careful are you when you check the air pressure. Pretty easy to dump a pound.
    From the only real Fargo, ND!
    Enjoy The Ride saddleman's Avatar
    Apr 2009
    Huntersville N.C.
    I would hope not I very seldom check air pressure & I ride 5 to 7 days a week. I might check my air pressure every other month.
    Dave Selvig
    2008 Black LT
    2004 Black LT
    2000 Canyon Red LT
    Registered User bigjohn72's Avatar
    Feb 2015
    Haskell, Arkansas
    Worse case scenario - but check to make sure your rims are not cracked anywhere. can do it with the soapy water / windex spray as suggested for the valve stem
    not to mention that if the bead area on the rim had not been cleaned, it can cause some leaking as well, again mentioned above by checking the bead for bubbles
    Big John in Arkansas
    2014 K1600 GTL
    2007 R1200GS Adventure (Sold)
    MOA# 200130
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    The OP never responded. This was another "how far can I go on bald tires?"
    The forum moderators have to start taking action on these absolutely, ridiculous posts.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Sep 2013
    Central Maine
    Quote Originally Posted by dieselyoda View Post
    What actions do you recommend the moderators take?
    You respond to a two week old post with thirteen response's that are pretty much identical and are upset that someone doesn't respond?
    I hope I'm missing a joke here, new meds have me a little off kilter.
  1. Losing things
    By henzilla in forum Campfire
    Last Post: 04-05-2014, 02:21 PM
  2. Losing Saddlebags?
    By dbrick in forum Hexheads/Camheads
    Last Post: 05-24-2011, 12:00 AM
  3. BMW losing another customer
    By eddiepat62 in forum Motorrad
    Last Post: 03-07-2011, 08:52 PM
