Results 1 to 9 of 9
Thread: Disconnecting GPS power lead
    Dec 2007
    Indiana
    I don't want to move the BMW GPS mounting bracket on my '19 F850GS...I want to remove it. Where/how do I "unplug" the bracket power cable? Looks sealed on bracket itself. Does it unplug from other end? Can't use a tank bag with this handlebar mounted bracket in the way.
    F850GS
    MOA #46783
    Dec 2010
    Boston
    My rt has a fitting to disconnect behind gages, hopefully your bike has a connector also.
    Dec 2010
    Boston
    I looked at ascycle’s site and saw this.
    Easy to disconnect
    The factory installed NAV prep unplugs fairly easily. The connector is up under the right side of the front panel. It barely visible if you get your head down to tank level and try to look under the front panel on the right side. My connector is white on the male left part of the connector (the cord to the nav holder) and black on the female right side of the connector (part of the motorcycle wiring harness). I have seen a photo of a connector where both parts were black so your mileage may vary. I have posted some photos on the F850GS Forum website.
    https://photos.850gs.com/image/HK6C
    https://photos.850gs.com/image/HvKO
    https://photos.850gs.com/image/HqB9
    The release button for the connector is on the black side of the connector (right side when installed) on the bottom. It is a tough spot to get your hand but it is doable. I ended up grabbing the white end with some bent nose needle nose pliers. BMW sells a $12 cap that goes on the wiring harness end of the connector. I used electrical tape to cover the end and then used some stick-on velcro to secure the loose piece up under the front panel.
    The cord that runs from the NAV holder is held in place with two rubber cable ties and 3 zip ties. Sorry for the TMI response, it's a five minute job that took me way too long to do. It was easy once it was done.
    Assuming your bike is TFT equipped
    In theory, BMW makes a non-TFT F850GS, but I've never seen one. The diagram that shows two ends to the nav holder cord might be for the non-TFT bikes. My NAV prep (TFT) has only a single connector.
    Mansfield,MA
    Quote Originally Posted by rimark View Post
    Some good info Those connectors are always easier after you've seen one....or done one.
    Mod Squad
    2009 F800GS 1994 TW200
    Dec 2007
    Indiana
    Thank you gentlemen. As soon as I kick this UTI (thank God for antibiotics), I'll get this done.
    F850GS
    MOA #46783
    Jun 2019
    Buena Vista CO & Marco Island FL
    Excellent information and photos. Saved me the trouble of asking.
    I may put mine back sometime, in a better location, but for now I’m just wanting it removed.
    Thanks guys!
    Dec 2007
    Indiana
    Finished the job. Thanks for your help. Mount is fine...but everything from triple clamp forward is now totaled. Should have waited till after antibiotics finished. But still got tank to put the bag on
    F850GS
    MOA #46783
  1. Switched power lead rear of 07RT
    By mikegalbicka in forum Hexheads/Camheads
    Last Post: 12-13-2015, 11:15 PM
  2. Switched power lead
    By selyab in forum Oilheads
    Last Post: 12-04-2011, 05:34 PM
  3. R1200GSA/fusebox/switched lead power
    By Tooth in forum Hexheads/Camheads
    Last Post: 08-24-2010, 11:29 PM
  4. Disconnecting the accessory socket
    By fracture in forum Hexheads/Camheads
    Last Post: 02-17-2009, 03:30 PM
  5. Switched power lead
    By ArthurKnowles in forum Oilheads
    Last Post: 01-25-2008, 01:07 PM
