Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: Gas leaking out of vent hoses
  1. #16
    Mar 2018
    Austin, Texas
    Tank vent hose
    I replaced my expensive rubber hoses that turned to dust in the tank with Tygon 4040 fuel line. Been over a year now with no issues.
    You can buy it on ebay, cheap.
  2. #17
    Mar 2019
    Tucson, AZ
    A little confused
    Are you looking through the gas filler hole to inspect the vent hoses? Have you removed the tank and are examining the vent hoses?
    I live in Tucson and the heat is serious. Fill on side stand, let pump hit stop, don't try to cram more in. Problem solved. (o, and **** canned the evap canister)
    I was just inside of mine and found a good tip- secure the vent hoses with a tie wrap. A little better than just being held with friction.
  3. #18
    May 2018
    Thousand Oaks, Ca.
    Quote Originally Posted by m4bmw View Post
    Ah! Thanks I wish I knew! I bought the expensive hose already but for the future.
  4. #19
    May 2018
    Thousand Oaks, Ca.
    Update
    So today I opened the tank and swapped out the vent hoses, I reused the factory clamps which wasn't that big a hassle actually. I went and filled the tank with gas and rode home. and so far...no gas coming from the vent hoses. Hopefully that is problem solved. I bought the hose from the UK BMW. With shipping it was $12 less than EME, how can they do that?
  5. #20
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Give it another year it will harden.
    It is not rated for continual submersion.
    I learned this from firsthand experience.
    Ufda happens..........
  1. 2004 R1150R with all vent hoses looped
    By onasteelhorse in forum Oilheads
    Last Post: 09-18-2018, 05:26 PM
  2. In tank vent hoses
    By 179212 in forum Oilheads
    Last Post: 05-15-2017, 02:51 PM
  3. 90 K75S vent hoses
    By jwetering in forum Flying Brick K-bikes
    Last Post: 02-12-2012, 03:52 AM
  4. Fuel vent hoses in the tank- how to replace
    By cb75076 in forum Oilheads
    Last Post: 07-21-2008, 01:44 PM
  5. 95 R100rt tank vent/overflow hoses
    By mikegates in forum Airheads
    Last Post: 03-06-2008, 03:35 AM
