Results 1 to 15 of 22
Thread: Gas leaking out of vent hoses
    May 2018
    Thousand Oaks, Ca.
    So just recently at fuel up gas will leak out of both tubes until the fuel level in the tank gets lower. Made me think the in bed vent hoses came loose. I opened the tank and the lines are secure top and bottom. I didn’t blow air through the hoses at the time but a hole in the hoses, both of them, can be the only reason, am I right about that?
    Thanks.
    Mar 2013
    Winnipeg, MB, Canada
    Happens to me: Fill tank right full with cold fuel, add heat from the sun when parked=gas puddle.
    I just adjust how much fuel I put in when I know the bike will be parked for a time or I fill it right full and then turn the throttle and go through the gears until I need more fuel or stop to pee.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Mansfield,MA
    Is that the deal that saturates the canister? Filling the tank extra full?
    Mod Squad
    2009 F800GS 1994 TW200
    Nibley, UT USA
    Quote Originally Posted by mykrs View Post
    I would suspect the two vent hoses submerged inside the tank. They may still be fastened tightly at their ends but the hoses may have cracked from age. Note that if you decide to replace them you’ll want submersible-rated (SAE 30R10) hose. Those lines are 5mmID x 10mmOD; bulk line is available in one-meter lengths from BMW. New clamps are a good idea, too—the OEM Oetiker clamps are a pain to work with but do the job well.
    Best,
    DeVern
    DGerber
    Nibley, UT USA
    Several things can do that. Filling the tank until fuel nearly overflows the “biscuit” vent-separator in the tank can do it, tho it is physically difficult to fill a tank that full. Other causes can include a biscuit that has fallen loose, a cracked or broken purge hose inside the tank (the one that’s connecting the cannister to the biscuit), a broken/dislodged/missing/poorly-replaced clamp on the purge line inside the tank, or misconnected vent and purge hoses (cross-connected). That latter one can contaminate the cannister with H2O draining down from around the fuel cap.
    But if one has a saturated cannister the usual approach is not to check the above, but to do a cannisterectomy. Which of course leads to that faint hint of gas fumes in the garage the morning after a fuel-up, and the nagging worry as to how that meshes with the gas-fired water heater mounted in the garage. But, I digress.
    Best,
    DeVern
    DGerber
    Mar 2013
    Or, It could be as simple as the tank is plastic, you put cold fuel in it, it shrinks, the sun warms it, the tank expands, so does the respective volume of fuel, pressure builds, exceeds the fuel cap relief capacity or even the fuel tank volume?
    Jul 2018
    Corralitos, CA - Santa Cruz County
    This happens to me only when I have filled to the top in morning on way into work and I leave on side stand instead of on center stand. No over flow on center stand.
    Signature
    Nibley, UT USA
    Quote Originally Posted by chrisinsc View Post
    That makes sense. On a full-to-the-top fillup, putting the bike on the sidestand dips the biscuit into the fuel and even tho the vent hole is on top of the biscuit it can be submerged and drain raw gasoline into the canister.
    Best,
    DeVern
    DGerber
    May 2018
    Thousand Oaks, Ca.
    Well I have filled the tank with just 3 gallons of gas and I still get the leak...so I have to assume that BOTH of the vent hoses in the tank have cracked at the same time? They're both connected top and bottom to fittings. So, that's my working theory.
    Now...
    Has anyone discovered submersible 5mm vent hose for less than $20 a foot? and I'm assuming I need 3 feet. Yikes!
    Thanks!
    Jul 2018
    I use BMW Motorworks UK for almost all my parts even though I am in the US. 2 day service for very reasonable prices. They also have a large selection of used parts.
    Signature
    May 2018
    Thousand Oaks, Ca.
    Thanks! I wasn't aware of them before. Will be giving them a look.
    Florida & Massachusetts
    Now...
    Thanks!
    You’re on the right track now. I got a one meter length of hose from max bmw, that I cut in half and it just fit.
    When did you last replace the u-shaped hose?
    May 2018
    Thousand Oaks, Ca.
    Quote Originally Posted by roger 04 rt View Post
    I never replaced the ushaped hose. I just got the bike.
    Max BMW, thanks, having a look. I went to a used bike shop today and bought some stuff for my bike at great prices and damn if he didn't cut those hoses when he removed the fuel pump to sell it. But i got a clean wind shield for $20, so that was a win.
    May 2018
    Thousand Oaks, Ca.
    Ordered hose from motor works in the UK. Even with shipping, how can it be cheaper than the US? It is, so I’m trying them out. Will update.
    Aug 2006
    Southern California
    For future reference.
    They have most everything, and located in Denver.
    Link:
    https://www.euromotoelectrics.com/category-s/2999.htm
  1. 2004 R1150R with all vent hoses looped
    By onasteelhorse in forum Oilheads
    Last Post: 09-18-2018, 05:26 PM
  2. In tank vent hoses
    By 179212 in forum Oilheads
    Last Post: 05-15-2017, 02:51 PM
  3. 90 K75S vent hoses
    By jwetering in forum Flying Brick K-bikes
    Last Post: 02-12-2012, 03:52 AM
  4. Fuel vent hoses in the tank- how to replace
    By cb75076 in forum Oilheads
    Last Post: 07-21-2008, 01:44 PM
  5. 95 R100rt tank vent/overflow hoses
    By mikegates in forum Airheads
    Last Post: 03-06-2008, 03:35 AM
