Results 1 to 7 of 7
Thread: 2018 Grand America: Bluetooth to analog speaker and bluetooth to bluetooth speaker
    Sep 2019
    Fallbrook, CA
    Here is my problem. i have galaxy S10+ and i have a Cardo Packtalk Bold unit attached to helmet and i have a bluetooth receiver with audio out cable and plug. I have paired my phone to the Cardo helmet unit and i have paired the phone to the bluetooth receiver whose audio out is plugged into the Aux in jack of the motorcycle located in right baggage bin.
    When i play music, the signal obviously goes from my phone to my helmet via bluetooth, but to the speakers it goes via bluetooth to receiver and then analog from receiver to speakers. The sound from the speakers comes out about .5 seconds before the sound in my helment. I would think the opposite should be true. In any event i can't get the tunes to sync up. the Packtalk has got the jbl earphones but the base out of speakers is much better. On the few times that the music has sync'ed, (by quickly changing source and back to Aux) it sounds great but then quickly goes back to helmet sound lagging speaker sound. I can't find a solution. Any help would be appreciated.... See attached image of current setup
    Attached Files Attached Files
    Jun 2018
    Ontario (GTA)
    Quote Originally Posted by mcorny1220 View Post
    There is no standard for synchronization of multiple audio sources over bluetooth.. AND the bluetooth receivers on your bike and in the helmet are running in completely different profiles (processing modes). The cardo is acting as a hands free device, the receiver is just that, a receiver. As a hands free device there is additional buffering/processing required for things like noise reduction and feedback cancellation. The receiver just has to decode the audio.
    As far as the bass response goes, are you sure you have the Cardo set up in bass boost mode? Use the app, not the webpage to confirm. Also the app may have to be running, I have never tried this out to verify. Anyhow, if you have bass boost on and you still find it inadequate you are probably out of luck as you are simply up against design constraints (size of speakers/amp power). You can switch from the JBL helmet speakers to earbuds which have good base performance, add a second cardo to bridge the audio to the bike so the two are in synch (don't take my word for it, borrow a set first), or listen to the bikes speakers. Oh, one other option would be to add a secondary amp to the cardo. There are companies that make these for phones, basically a small inline amp that receives high level inputs and outputs boosted audio signals. But then you have wires and battery to contend with.
    Anyhow, food for thought.
    Sep 2019
    Fallbrook, CA
    Thanks for the reply. Not sure i know what you mean by having a second cardo (i have an extra Freecom 4) bridge the audio to the bike's external speakers. how is that done?
    Sep 2019
    Fallbrook, CA
    Does anyone else have any input/suggestions on this isssue please?
    Jun 2018
    Ontario (GTA)
    What I meant was the only way to equalize the latency (time differential) between what you hear in your headset and what you hear on the bikes speakers is to make the signal path the same. The rediculous solution for this would be to stick a second cardo into the right cubby and run its output into the bikes aux in. (plug aux in directly into cardo output). Its a silly idea but in theory it should work.
    Sep 2019
    Fallbrook, CA
    the packtalk bold does not have an audio out jack from which i could plug a cable from it to aux in of motorcycle. If Bmw allowed the front speakers to stay alive when using bluetooth that would solve the problem. Has anyhone figured out how to circumvent the automatic turn-off of speakers when on blue tooth?
    Jun 2018
    Ontario (GTA)
    I was being facetious as this would be an overkill solution but ... yes, the packtalk bold has an audio out jack, that is what the speakers are plugged into. You need an adapter of course but it is a low level, amplified at low level audio output jack. This is what allows you to plug in speakers from a different manufacturer or to take packtalk speakers and use them on any other audio headset with at 3.5mm jack. Think back to a phone with a headphone output jack, you could by a 3.5mm to RCA Y-cable and plug that into your home amp and playback your phone on your home stereo.. same thing. But again, I was being facetious as this would be an expensive solution. I am not sure what problem you are trying to solve but playing audio out of both the bike speakers and the helmet speakers doesn't sound like a solution to pursue.
  1. Bluetooth Pairing Issues with 2014 Schuberth C3 Pro, NAV V, and 2018 K1600GTL
    By landcruiser15 in forum Straight 6 K1600 GT/GTL/B
    Last Post: 05-11-2019, 02:39 AM
  2. Bluetooth connecting to a Nolan Bluetooth 3 helmet
    By maurice in forum Straight 6 K1600 GT/GTL/B
    Last Post: 02-15-2017, 02:11 AM
  3. Replies: 0
    Last Post: 10-10-2014, 04:03 AM
  4. Bluetooth that does work well with 2011 RT's Bluetooth
    By jdsdtourteam in forum Hexheads/Camheads
    Last Post: 06-16-2011, 03:03 AM
