Results 16 to 20 of 20
Thread: Does anyone know ?? Rear Drive Compatibility
    Nice price if its as advertised! It certainly appears that it will fit your 1200S. I'll venture a guess that one should work.
    If the photo is correct and the description is in error it should work. If the description is correct and the photo is not, then it won't work. Call the seller and ask which is correct.
    ADDED: I just got on eBay and contacted the seller to point out the discrepancy between the description and the photograph. The question and answer should show up on the item page. If I get a direct response I'll let the Forum know.
    Nibley, UT USA
    Just thought of something. You may want to look for one that has a drain plug in the bottom.
    I don't know what year they started using a drain plug.
    The drain plug adds convenience in servicing, but negates the one one advantage of the earlier drives—where changing gear lube forced an inspection of the splines on the FD. I like to think BMW Engineering considered that in the design, hence the lack of an easily accessible drain plug. Then Marketing stepped in, and “Lubed for Life” was born. Later, the drain plug got added due to customer feedback, FD splines started getting ignored, Engineering got to point out how stupid Marketing can be, and here we are...
    Best,
    DeVern
    DGerber
    I received an answer from the ebay seller - see my Post # 16 - and the seller confirmed that the photo is correct and the description is incorrect.
    The seller's response was, "Thank you for looking at our products,
    You are absolutely right and thank you for pointing it out to me, the pictures are the right ones.
    I took them a fews days ago. I will change the text description accordingly to a K1200S/GT or K1300S/GT."
    Debbie's Servant Lee's Avatar
    SW Iowa
    I received an answer from the ebay seller - see my Post # xx - and the seller confirmed that the photo is correct and the description is incorrect.
    Now that we know for sure, it looks like a good price.
    Lee
    2016 R1200RS
    MOA # 30878
    DBLUPPR snookers's Avatar
    Jul 2010
    Niagara Wine Region
    Thankyou Gentlemen for your interest and responses......an offer has been made, so now we wait.....
    2000 R1100RT , 2005 K1200S w/hack
    Niagara BMW Riders #298 BMWMCO #45
    "Always look on the bright side of life" (Monte Python)
  1. new rear drive
    By jkmolt in forum Sidecars and Trikes
    Last Post: 03-26-2014, 07:43 PM
  2. Rear drive compatibility
    By 77158 in forum Airheads
    Last Post: 02-14-2008, 11:02 PM
  3. k75 rear drive
    By drrider2 in forum Flying Brick K-bikes
    Last Post: 09-12-2003, 04:16 PM
  4. k11 k12 rear drive
    By eric2 in forum Flying Brick K-bikes
    Last Post: 09-06-2003, 02:59 AM
