I just got a new lock cylinder for my system case on my '03 K1200GT. I followed BMW instructions to match the new lock to my existing key. Instructions end with "Performance test". The key works--lock opens and closes fine. Thought I was done, but found the key would not come out of the lock cylinder. I can't figure out how to remove the cylinder, either. Will I be able to remove it if I remove the assembly that has the locking mechanism and handle?
Does had to fix this problem? Could a locksmith do it?
Thanks, any advice will be appreciated.
