Results 1 to 6 of 6
Thread: '03 K1200GT Key stuck in lock cylinder
    Minnesota
    I just got a new lock cylinder for my system case on my '03 K1200GT. I followed BMW instructions to match the new lock to my existing key. Instructions end with "Performance test". The key works--lock opens and closes fine. Thought I was done, but found the key would not come out of the lock cylinder. I can't figure out how to remove the cylinder, either. Will I be able to remove it if I remove the assembly that has the locking mechanism and handle?
    Does had to fix this problem? Could a locksmith do it?
    Thanks, any advice will be appreciated.
    Liaison 20774's Avatar
    I'm not sure how much it applies, but there is a DIY in the K-Bike library about locks and cylinders:
    https://forums.bmwmoa.org/showthread...Rekeying-Locks
    Registered User AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    Look here under "Removal" and you will see a pic of how to do it:
    http://largiader.com/tech/locks/double.html
    Anton Largiader 72724
    Tech articles - YouTube
    Virginia Motorrad Werkstatt BMW motorcycle service and repair in central Virginia
    Minnesota
    Thank you both for the responses. Very helpful. I also got a response on K-bikes.com with a link to a video on cylinder removal: https://youtu.be/1Ul9BjNjKQk
    Still don't know if I'll try rekeying myself again.
    Jul 2004
    Charlottesville, VA
    Quote Originally Posted by lljanssen View Post
    The likely cause of your inability to remove the key is the 7th wafer. That spot should be empty. From the bottom, you should have the big release wafer, then a blank, then six numbered wafers. If you put a wafer in that empty spot for bags, the key won't come out. IIRC that spot is only used for ignition locks.
    Minnesota
    You are right. I mixed up the instructions for the ignition and the bag lock. Once I figured that out and did it correctly, it worked fine. Thanks again.
  1. 1994 K75 Lock cylinder
    By guaire in forum Flying Brick K-bikes
    Last Post: 04-08-2019, 03:34 AM
  2. Disassembly of a lock cylinder when re keying
    By flhfxd in forum Oilheads
    Last Post: 08-11-2018, 09:03 PM
  3. Seat Lock Stuck
    By andyroto in forum Wetheads
    Last Post: 09-13-2015, 03:49 PM
  4. Broken tap stuck in cylinder head
    By lazygoodan in forum Oilheads
    Last Post: 10-02-2010, 09:34 PM
  5. Only firing on 1 cylinder, stuck at work!
    By DYLAN76 in forum Airheads
    Last Post: 09-03-2006, 05:09 PM
