Results 1 to 10 of 10
Thread: K1600 Recall Data Published in the Netherlands! IMPORTANT!
    BMW K1600 Recall Netherlands Data.pdf
    Here is what was released to Motor.NL by BMW.
    Apparently two gears can engage at once, causing rear wheel lock-up.
    I've talked to two dealers in the Midwest and they have no K's in for gear box issues.
    FWIW
    Liaison 20774's Avatar
    Not a lot of details there...any idea as to the year range of the bike?
    Click the PDF?
    I think the PDF had tons of data.
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    Quote Originally Posted by millerj0545 View Post
    I missed the 'tons' part.
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Ugh
    The PDF for some reason contained an image that had more of the data - it was missing during the print:
    BMW Motorrad recalls the BMW K1600 GT / GTL / Dredger / Grand America to replace parts of the gearbox. It is specifically about the models
    K 1600 GT (0F01 / 0F11)
    K 1600 GTL (0F02 / 0F12)
    K 1600 Dredger (0F51 / 0F53)
    K 1600 Grand America (0F51 / 0F53)
    which are produced between September 2016 and September 2019 .
    Sep 2009
    Chestnut Hill, MA
    NHTSA (USA's Recall authority) has no information. Looks like 462 bikes affected in the Netherlands.
    John Gamel - BMW MOA Consumer Liaison
    2015 Ebony Metallic R1200RT
    “So often times it happens that we live our lives in chains
    And we never even know we have the key”
    Debbie's Servant Lee's Avatar
    SW Iowa
    Here's the thread about the stop sale order.
    https://forums.bmwmoa.org/showthread...2018-all-K1600
    Lee
    2016 R1200RS
    MOA # 30878
    Mansfield,MA
    If it a problem with the shifter fork, anybody check to see how “deep” it is in the engine?
    I did a shifter fork on a Honda years ago. From where the shift lever attached, the rod went clear through to the other side of the engine where the actual “Y” shaped was attached (to the rod). It was most likely pretty simple compared to having 5 more cylinders to work around.
    Mod Squad
    2009 F800GS 1994 TW200
    SW Iowa
    Seems like the K1300 transmission slid out the side. The K1600 probably has the same type of transmission.
    Lee
    2016 R1200RS
    MOA # 30878
    Aug 2018
    Fargo, ND
    Yes, the K1600 transmission will come off the engine as an assembly. I wonder if BMW will trust techs to do the repair or just swap out the assembly?
    When Yamaha came out with a new R1 back in '16(?) they discovered a gear problem with the transmission. Yamaha recalled all of the R1s and repaired the transmission. The engine had to be removed from the motorcycle and engine cases split to get to the transmission. It was a big job and only certain dealers and techs were allowed by Yamaha to do the repair.
    From the only real Fargo, ND!
  1. new member from the Netherlands
    By bvrees in forum New Members
    Last Post: 01-21-2018, 08:10 PM
  2. another new member from the netherlands
    By avrees in forum New Members
    Last Post: 01-21-2018, 04:43 PM
  3. Replies: 15
    Last Post: 11-10-2012, 03:44 AM
  4. New Posting Guidelines published
    By Visian in forum Campfire
    Last Post: 01-14-2008, 11:58 PM
