Results 1 to 5 of 5
Thread: 03 1150GSA Fork Lock Problem
    Jun 2019
    Greenville SC
    I have an 03 1150GSA. I canít get the fork to lock when I park the bike. Manual says to turn key to lock and turn bars fully left. When I have key at lock the fork doesnít lock and the key canít be removed... any ideas on what Iím doing wrong? Iíve tried turn bars left then turning key and vice versa.
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    You may have to wiggle the bars a bit to get the lock to engage. It's a bit fiddly from what I remember... Perhaps the whole thing needs a cleaning after 16 years....
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, Ď17 R1200RT
    Mansfield,MA
    Welcome to the forum!
    This comes up from time to time. Older bikes, especially where the fork lock was seldom used, need to be ďlimberedĒ up. I can suggest a few applications of WD-40 and working the mechanism a bit. There have also been a few cases where an accessory would not let the forks turn enough.
    Chances are you will be able to free it up.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Jun 2019
    Greenville SC
    Thanks for the advice! I turned all the way left. Then as I kept pressure on the key towards lock, I slowly moved the bars to the right and it clicked into place. Problem solved. I did go ahead and spray a little lube on the lock just in case...
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Be sure not to go all the way CCW with the key!
    If you go to the end click the parking lights will come on.
    Do that on a sunny day w/o noticing and you will mostly likely return to a weak or dead battery.
    Ufda happens..........
  1. '02 1150GSA Drive Shaft Problem?
    By Ron from BC in forum Oilheads
    Last Post: 08-31-2017, 12:29 AM
  2. R90/6 fork lock
    By DAVIS2X1 in forum Airheads
    Last Post: 04-19-2010, 01:29 PM
  3. Fork Lock Cover . . . .
    By CTellman in forum Airheads
    Last Post: 12-07-2008, 11:07 PM
  4. Fork Lock Removal
    By r80r100rt in forum Airheads
    Last Post: 07-26-2006, 01:04 PM
  5. /2 fork lock key blanks
    By bensonhurst in forum Vintage
    Last Post: 06-20-2006, 02:12 AM
