Results 1 to 9 of 9
Thread: tire pressures, and exhaust fumes
    jimmy armour
    Jul 2009
    Lucknow ontario canada
    Hi ,just back from a weekend in the Haliburton highlands Ontario riding behind my son on the 2000 r1100rt,I couldnt help but notice the smell of his exaust mostly at lower speeds or while running down hill, it idles perfectly and hessitates slightly at lower speeds, as far as I have been told is quite normal,what should I check? also put new metzeler tires on it and what should the tire pressures be ,thanking you in advance Jimmy
    Left Coast Rider
    Nov 2011
    1. Running slightly rich?
    2. I'd start with manufacturer's (BMW) tire pressure recommendation and modify to taste.
    jimmy armour
    Jul 2009
    running slightly rich
    Thanks for resonding, there is no blue or black smoke just slight smelly exaust fumes? this is the first I have ridden behind the bike ,can the mixture be adjusted ? as there is only one adjustment on the right inj body ,once again thanks in advance Jimmy
    Quote Originally Posted by jimwjarmour View Post
    Mixture is computer controlled. The adjuster you see (big brass screw) is just an air bypass adjustment to set idle speed.
    The square black box on the left throttle body is the throttle position sensor that informs the computer how wide open the throttle is. It might not be correctly adjusted but the O2 sensor in the exhaust ought to cause the ECU to correct the mixture within some limits.
    I would not fiddle with anything until a complete regular tune up including valve adjustment, throttle body synchronization and new spark plugs was accomplished.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Does he have a aftermarket exhaust that eliminated the cat?
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User K7GLE's Avatar
    Apr 2016
    Seattle
    Quote Originally Posted by BC1100S View Post
    I fiddled with pressures on my '00 RT for quite a while (generally running PR3's) and have settled on 36F/42R, loaded or not, but always one-up.
    - Glenn
    2000 R1100RT (current)
    1982 R100RT (traded)
    1970 BSA A65T, 1969 Honda CB350, 1967 Honda CB160 all fondly remembered
    jimmy armour
    Jul 2009
    thanks again,
    well thanks again, standard exaust new plugs valve adjustment full service inc air filter about 6000 km,s ago I was wondering about the o2 unit in the exaust ? can it be cleaned or just replaced, is there a test ?, bike rides great just now that my son is riding it and I am back on my old airhead that I am now noticeing the smell ,re tire pressures again new metzlers fitted at 35 front 38 rear just like my airhead, but now the front has worn into a wave pattern mostly on the left side !I am thinking too low pressure thanks for the help, Jimmy
    Apr 2016
    Seattle
    I used to get a fair amount of exhaust smell from my airhead at idle. IIRC the header-to-cylinder connection allows a fair amount of gap, and anything wafting up would get captured by the fairing for my enjoyment.
    - Glenn
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    Look for oil leaks, particularly the oil pressure sensor leaking onto the header.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
  1. Tire Pressures
    By ItsPhilD in forum Scooters
    Last Post: 09-17-2013, 07:32 PM
  2. Tire Pressures
    By jhglaw in forum F-Twins
    Last Post: 02-22-2010, 07:19 PM
  3. K75 exhaust fumes
    By BILLK75 in forum Flying Brick K-bikes
    Last Post: 10-22-2009, 05:48 PM
  4. k75s tire pressures
    By k75sboy in forum Flying Brick K-bikes
    Last Post: 07-04-2004, 03:54 AM
  5. CLC Tire Pressures
    By HELLIOTT in forum Oilheads
    Last Post: 10-13-2003, 09:52 AM
