Results 1 to 8 of 8
Thread: What Oil?
    What Oil?
    I'm sure it's been asked before, but what oil should I be using in my new 2019 K1600GT that won't bankrupt me like the BMW oil?
    Penzoil 5W40 EU?
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    If 5w-40 is the correct weight Castrol Power1 4T meets the specs.
    $45 for a 6 pack.
    https://smile.amazon.com/dp/B008MISD...v_ov_lig_dp_it
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    With a wet clutch, automotive oil is out of the question due to friction modifiers that will wreck the wet clutch. MA2 rating is a must.
    I find Liqui Moly from Beemerboneyard to be a great alternative to BMW oil and in spite of the name, there is no molybdenum in the oil... YMMV
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, ‘17 R1200RT
    Registered User jonnybow's Avatar
    Apr 2019
    Delaware
    $53 for a 6 pack.
    This is what I use and where I get it. Sometimes you'll find this on sale and I buy a few cases. You can also get the filters and crush washers from Amazon.
    While you're at it, make the change simple and buy the super plug from RL on the K1600forum
    Jon
    K1600GT & R1200GSA
    Wallyworld to the rescue
    Quote Originally Posted by millerj0545 View Post
    Penzoil 5W40 EU?
    I use Shell Rotella T6 5W40, $22 for 4 quarts full synthetic and has the JASO rating. Put 52K on a 16 r1200rt using this oil and checked the valves myself recently. Top end looked great and no oil film or sludge visible at all, engine burns no oil between changes. I am happy to use this in my 18 K1600 bagger.
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    Castrol Power1 4T 5W-40 Synthetic Motorcycle Oil.
    Mahle OC-306 Filter.
    Get yourself a long 5MM hex socket. I use this one: http://www.gearwrench.com/3-8-drive-...ocket-5mm.html
    Do not get a ball-end. You'll chew up the secondary drain plug and you'll be sad.
    You'll also need an 8MM hex for the main drain.
    Have fun.
    Joe
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Quote Originally Posted by Igotone2 View Post
    I use Shell Rotella T6 5W40, $22 for 4 quarts full synthetic and has the JASO rating. ...
    Here is a link to info on Shell Rotella T6 5W-40. This oil does claim to meet the MA2 standard.
    https://rotella.shell.com/en_us/prod...f/t6-5w-40.pdf
