Results 1 to 4 of 4
Thread: Hard Box Scratch
    Hard Box Scratch
    I purchased a 2011 R1200RT this past summer and it had been well maintained, no scratches. Yesterday I opened the left side hard box and didn't realize that the restraining strap had unhooked, so now I have an ugly scratch on the top of the box where it hit the ground - depressing! Does anyone have a tip for touching up the scratch so it doesn't look so bad? I hope BMW has come up with a better design for the restraining strap since 2011.
    Liaison 20774's Avatar
    I hate when that happens! Check some of the threads in the Similar Threads pane at the bottom of the screen.
    I've been using a metal polishing compound by Blue Magic called Metal Polish Cream on some brass items. A similar product would be Simichrome Polish. While they indicate for metals, I suspect they might do a good job on hard surfaces as well. Try in a less-seen place first.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Kurt he probably had painted lid on his RT.
    At first when he mentioned boxes I was thing GS aluminum bags.
    Lee
    2016 R1200RS
    MOA # 30878
    Sep 2013
    Central Maine
    How deep is the scratch? Can you feel it with your fingernail? If so, I'd start with a touch up pen in the scratch, try and apply it somewhat proud of the surface. Use 1000 grit to wet sand smooth the touch up, then switch to 1500 then 2000 wet sanding both. After sanding get some 3M swirl remover and polish out sanding scratches. If it's not very deep you can try just the swirl remover. Good luck.
  1. Scratch on Instrument Cluster
    By poco183 in forum Wetheads
    Last Post: 06-11-2019, 02:28 PM
  2. Scratch removal
    By lubedude in forum Motorrad
    Last Post: 02-18-2016, 06:10 PM
  3. K75 windshield material and scratch removal
    By WalterK75 in forum Flying Brick K-bikes
    Last Post: 04-17-2010, 12:05 PM
  4. 1:5 Scale Scratch Built R/32 Model
    By pirana in forum Motorrad
    Last Post: 02-19-2010, 11:33 PM
