Results 1 to 15 of 18
Thread: Navigator V Garmin update
    Registered User pettynerd's Avatar
    Oct 2008
    Hudson, WI
    Anyone able to update the map to version 2020.20 on the Navigator V? It was the one released July 17th, 2019
    I've tried multiple times and it gets to 51.8% downloaded before it pops up an error and shuts the GPS unit off.
    Thought I'd try here before try Garmin help
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    I did both of our Nav Vs this summer.
    One did not complete the download but when I tried the 2nd time it completed the download.
    Did you check to make sure the memory is not full?
    Lee
    2016 R1200RS
    MOA # 30878
    Rich Pelton Rich's Avatar
    Sep 2003
    Killdeer, ND
    I did mine with no issues.
    Registered User powwow's Avatar
    Aug 2015
    Bend, OR
    Mine downloaded with no issues.
    Larry Gregerson; Bend, OR
    MOA #93031
    Sep 2015
    Birmingham, AL
    Quote Originally Posted by pettynerd View Post
    What was the error message? Google it! As has been said, the download is clean. Are you out of memory? Do you have a lot of videos/MP3's downloaded to the NAV V? Do you have the latest Garmin updater/installer on your PC? Map 20.20 has been out for several months.
    J Goertz
    BMW MOAL
    2015 BMW R1200RT
    2012 Triumph Bonneville SE
    Oct 2008
    Hudson, WI
    Thanks for the feedback, looks like it's on my end.
    For the memory I have 6 GB open out of the 7 GB and the update is 5.82 GB so I should be good there.
    The error doesn't really say anything, the Garmin was connected to the computer until the error and then is disconnected so that's why it's showing Not Connected.
    Name:  garmin update error.JPG
    Sep 2015
    Birmingham, AL
    Try installing the update to your computer, then use MapInstall (one of the options of BaseCamp) to install it to your Garmin. I have to do the updates to my Montana this way. It may work for you on your NavV. I have a 3rd Garmin (a Nuvi 2739) that sometimes disconnects w/o warning on long updates. The two-step method works everytime on the Nuvi. I think it has something to do with the long pauses that Garmin Express has in transferring files from the Garmin Site to the PC, then to the NavV. If there is a long pause, sometimes the NavV will disconnect. (Again, I don't have this problem using MapInstall to transfer the map update to the NavV).
    Good luck!
    J Goertz
    BMW MOAL
    2015 BMW R1200RT
    I tried once and it crapped out without doing the install. Tried again a few weeks later and it worked fine. I've had the same issue with numerous other Garmin devices, but on those it was always not enough memory. In general, the Garmin update process could use improvement.
    Aug 2013
    Bedford, Nova Scotia
    I believe your problem might be that while the update itself may be 5.82 GB it often take more free space than the actual file size to do an update. Perhaps because not all files are deleted before the update or something like that. Garmin seems to have this issue more than others.
    I'd suggest you see if there are files you don't need on the unit and delete those. Typically you can delete the language files that you are not using and other such items. I do this to all my units as more free memory typically translates to quicker responses etc.
    Regards, Alan - President BMWONS - BMWMOA/BMWRA/BMWONS/Airheads
    Current: 2019 R1250RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '14 R1200RT / '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
    ...never too much lefse
    Aug 2009
    Connecticut
    Nav V thinks it is lining in 2000
    After the most recent update, I noticed that my Nav V thinks the date is March 23, 2000 and I cannot find a way to change it. I've tried a soft reset. No luck. I tried a hard reset. No luck except I wiped out all of my BT connections, data, and Apps. I tried a Restore to the oldest backup I could find. No luck. Something is happening when it receives the Sat. data. It will properly reset the time but it cannot get off the date of March 2000.
    I have manually reset my R12GS (2015) clock to the proper date without the GPS installed. When I install the GPS and watch the date on the bike, it "updates" to March 2000 when the GPS gets the green bars for sat. reception.
    The calendar setting on the bike is not a big deal to me but I would like to get the GPS date right since it thinks sunset is a lot later (it thinks it is springtime) and the Night mode switches on about 90 minutes too late.
    Any ideas on how I can remedy a GPS that thinks it is 18 1/2 years younger than it really is would be greatly appreciated.
    Robert Horton
    riding - 15 R1200GSW
    gone - 95 K75RT
    May 2003
    SW Iowa
    Quote Originally Posted by sleeper View Post
    In case others did not see my reply to your thread, several people are having the same problem.
    Garmin is aware of the problem and working on it.
    One problem with your bike having the wrong date, it can trigger the service reminder.
    Lee
    2016 R1200RS
    MOA # 30878
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    Newer maps
    The new map set is 2020.30
    Once installed, don't forget to delete your old maps to free up some space.
    They take up almost 4 gigs.
    Joe
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    May 2003
    SW Iowa
    Quote Originally Posted by 61996 View Post
    Joe
    Can you list the steps to delete the old maps.
    I thought old maps were automatically deleted when you install new ones.
    Lee
    2016 R1200RS
    MOA # 30878
    Mar 2014
    Apple Valley, MN
    They're still sitting there.
    Just go to "Add/Remove" programs and they should be listed.
    Joe
    May 2003
    SW Iowa
    After I replied the last time I googled how to remove the old maps.
    Several places said to not deleted the preinstalled map. Only delete supplemental maps that have been added.
    I do know map file sizes keep getting larger each year as more detail is added.
    Lee
    2016 R1200RS
    MOA # 30878
  16. 11-09-2019, 01:18 AM
    Reason
    Wrong topic
  1. Replies: 7
    Last Post: 06-20-2018, 12:22 AM
  2. Garmin Express and Garmin Map Update 2018.20
    By ExGMan in forum Motorrad
    Last Post: 08-25-2017, 03:40 AM
  3. New Map Update - Navigator V
    By ExGMan in forum Wetheads
    Last Post: 02-16-2016, 02:38 PM
  4. Replies: 16
    Last Post: 11-04-2015, 07:57 PM
  5. Navigator III update fail
    By 185274 in forum Gear
    Last Post: 07-02-2013, 05:45 PM
