Results 1 to 6 of 6
Thread: R90S front turn signals loose after steering head bearing replacement
    Registered User sirmanley's Avatar
    Oct 2005
    St. Louis MO
    Just replaced my steering head bearings. Now my front turn signals are loose. Even with the S fairing installed the turn signal stems flop up and down about 1/8 inch. I remember them being much tighter than that. The rubber for the headlight bucket mount look OK. Anything I should look for when I strip it back down?
    Sir Manley, of the Britches that squeak
    1996 R1100R, the mighty Dragon Slayer
    1975 R60/6, Cafe 60
    Liaison 20774's Avatar
    Could you show the current setup for your signals? For some reason, I thought they mounted to the sides of the fairing. Do they go thru and attach somewhere else?
    Rally Rat 1074's Avatar
    Sep 2004
    Las Vegas, NV
    As long as all the parts are in place then the fork tubes are too high in the lower clamps. There is a measurement, I think quoted in the factory. for the height.
    Boxerbruce
    I wouldn't ride it until you resolved the floppy turn signal stalks!
    It sounds like you either missed something or the top clamp (handlebar mounting plate) is not correctly installed. Even without the extra support from the stalks passing through fairing those turn signal stalks should barely move even with some pressure. I would strongly recommend going back in and checking the work before you test ride it.
    R90s
    Quote Originally Posted by sirmanley View Post
    What year? 1974's had aluminum housings. My '74 requires almost full compression of the T.S. housing to clamp tight to the mount. The '75 and '76 models were clamped to the mount via an internal u-clamp in the housing.
    I can't see how installing new steering head bearings would have anything to do with the mounts.
    jimmy armour
    Jul 2009
    Lucknow ontario canada
    loose turn signals
    Hi, there are 2 roll pins one on each side to locate the turn signal brackets with a notch in the bottom rubber head lamp bracket there is also a rubber ring on the top also since you changed the steer head bearings make sure the bearing cups are well seated, while tightning the top fork nuts, hammer a steel screw driver into the clamp slot with the screws removed, while tightning the top nuts each side, all should tighten up the headlight brackets and therfore the turn signal brackets on the rubber rings, but I would,nt go too far the way it is, what I do if I have been working around the streering head I run up and down a rough road hitting as many bumps as I can ,she will knock or rattle if too loose also loosen your grip at around 30 to 40 mph and if she shakes her head another sign of loose steering, note a worn rear tire can give the same symton best of luck hope this assists ,Jimmy
  1. Loose turn signals
    By georgej in forum Airheads
    Last Post: 06-01-2019, 02:08 AM
  2. Replies: 2
    Last Post: 11-24-2018, 04:27 PM
  3. Steering head bearing too loose/too tight
    By bmwgsrider in forum F-Twins
    Last Post: 05-14-2012, 12:46 AM
  4. Any Tips for steering head bearing replacement?
    By KCinSB in forum Flying Brick K-bikes
    Last Post: 06-29-2008, 03:56 PM
  5. Steering head bearing
    By ccolwell in forum Airheads
    Last Post: 04-21-2008, 11:53 AM
