Yeah, it’s a bummer. I just purchased the 2019 K1600B with the Monolith special paint , but now have to wait until the issue is resolved before I can take her home .
Nope... they admitted that they haven’t heard anything. They weren’t even sure what the problem was, although we now know it’s the shift fork. So I don’t have a clue how long this wait will be. Very frustrating .
It will translate for you.....but here is the PDF in English just to be safe.View attachment 75828
That sounds like it's going to be an expensive repair. Won't be done overnight either...
It might not be terrible. The K1600 uses a "cassette" transmission design, so the gears and shafts can be slid out of the bike without splitting the crankcase or tearing the bike in two - unlike the R bikes.
Still, lots of little bits to be removed in preparation:
Preparatory work
Removing gearbox cover
Removing left bottom side panel
Removing left radiator cowl
Removing left side panel
Removing left stowage compartment
Removing right bottom side panel
Removing right radiator cowl
Remove the right side panel
Removing carrier for right bottom side panel
Removing right drop-protection pad
Removing left catalytic-converter shield
Disengaging clamp on left silencer
Removing left silencer
Removing right crankcase cover
Removing clutch
Removing number-plate carrier
Remove the rear wheel
Removing rear brake caliper
Disengaging shift lever
Removing left footrest plate
Disengaging gearbox potentiometer
Removing clutch slave cylinder
Remove the pushrod
Disengaging mounted parts from gearbox
Disengaging actuator rod from rear ride height sensor
Releasing Paralever link at rear
Lowering bevel gears
Disengaging universal shaft
Core activity
Removing gearbox
I suppose the techs have (or will find) some shortcuts in that list. The RepROM shows 38 Flat Rate Units to prep, remove, strip and re-assemble the gearbox, which includes dis-assembly of every shaft, bearing and gear. Google tells me a FRU can be anywhere from 5 to 10 minutes - it has changed over the years and is different for service and warranty work. I'll guess it will be a 3-5 hour job after the tech has done one or two.
The time to simply remove and replace the gearbox on my '06 RT is 54 FRUs, without actually opening it up.
