Results 1 to 15 of 16
Thread: Stop Sale Transmission 2016 2018 all K1600
    Not so good news.
    It appears there is a issue with the shift fork on the K1600.
    11/2016 to 9/ 2019 models effected.
    Ian
    Mansfield,MA
    Welcome to the forum!
    I guess the good news is that BMW will cover it.
    There have been a few of these for the bikes and a few for BMW’s high end cars......the cover it.
    Again, welcome.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Bmw not issuing a ride stop
    According to CycleWorks of Barrington this is not a safety or significant mechanical issue - BMW will not be issuing a Ride Stop order. More to follow.....
    Registered User lasnin's Avatar
    Jul 2017
    Susanville, California
    Shift fork
    I was looking at buying a K1600B, and then was contacted by a dealership stating the “stop sale” due to shift fork issues..... maybe I’ll keep my 2016 R1200RT and be happy with its having no issues....
    Stop Sell
    Yeah, it’s a bummer. I just purchased the 2019 K1600B with the Monolith special paint 😁, but now have to wait until the issue is resolved before I can take her home 😫.
    Jul 2017
    Timeline for stop sale?
    Quote Originally Posted by dave23913 View Post
    Did they give you any timeline???
    Stop sell
    Nope... they admitted that they haven’t heard anything. They weren’t even sure what the problem was, although we now know it’s the shift fork. So I don’t have a clue how long this wait will be. Very frustrating 😡.
    Jul 2017
    I can’t imagine your frustration...... I would be so itching to ride that bike! I guess I’ll pass the upcoming Winter months thinking about a K1600B...
    I hope that you get your bike soon!
    Jul 2017
    English translation
    Thank you for the link! Now I need to work my Dutch to English translations
    Use Google Chrome
    It will translate for you.....but here is the PDF in English just to be safe.BMW Recall K1600.pdf
    Jul 2017
    Critical Driving Situation
    Quote Originally Posted by millerj0545 View Post
    Thank you for the PDF..... I like to avoid those “critical driving situations,” especially at high speeds...
    More importantly, can I get a “Dredger” and not a “Bagger” at my dealership?
    May 2007
    Western NY
    This has now become a recall in the US. The recall number is 19V692. Here is what's available on the NHTSA website.
    "Summary
    BMW of North America, LLC (BMW) is recalling certain 2017-2020 K 1600 GT and 2018-2020 K 1600 GTL and K 1600 B motorcycles. Certain transmission parts may not have been produced to the appropriate hardness level. This could affect the function of the transmission, possibly causing double engagement of two gears and/or the damage of transmission parts.
    Remedy
    BMW will notify owners, and dealers will replace the shift forks, the selector sleeve of 5th/6th gear and the gear wheel of 6th gear, free of charge. The recall is expected to begin October 17, 2019. Owners may contact BMW customer service at 1-800-525-7417."
    Karl
    2007 R1200ST
    Sep 2009
    Chestnut Hill, MA
    That sounds like it's going to be an expensive repair. Won't be done overnight either...
    John Gamel - BMW MOA Consumer Liaison
    2015 Ebony Metallic R1200RT
    “So often times it happens that we live our lives in chains
    And we never even know we have the key”
    Nov 2011
    Central Ohio
    Quote Originally Posted by ExGMan View Post
    It might not be terrible. The K1600 uses a "cassette" transmission design, so the gears and shafts can be slid out of the bike without splitting the crankcase or tearing the bike in two - unlike the R bikes.
    Still, lots of little bits to be removed in preparation:
    Preparatory work
    Removing gearbox cover
    Removing left bottom side panel
    Removing left radiator cowl
    Removing left side panel
    Removing left stowage compartment
    Removing right bottom side panel
    Removing right radiator cowl
    Remove the right side panel
    Removing carrier for right bottom side panel
    Removing right drop-protection pad
    Removing left catalytic-converter shield
    Disengaging clamp on left silencer
    Removing left silencer
    Removing right crankcase cover
    Removing clutch
    Removing number-plate carrier
    Remove the rear wheel
    Removing rear brake caliper
    Disengaging shift lever
    Removing left footrest plate
    Disengaging gearbox potentiometer
    Removing clutch slave cylinder
    Remove the pushrod
    Disengaging mounted parts from gearbox
    Disengaging actuator rod from rear ride height sensor
    Releasing Paralever link at rear
    Lowering bevel gears
    Disengaging universal shaft
    Core activity
    Removing gearbox
    I suppose the techs have (or will find) some shortcuts in that list. The RepROM shows 38 Flat Rate Units to prep, remove, strip and re-assemble the gearbox, which includes dis-assembly of every shaft, bearing and gear. Google tells me a FRU can be anywhere from 5 to 10 minutes - it has changed over the years and is different for service and warranty work. I'll guess it will be a 3-5 hour job after the tech has done one or two.
    The time to simply remove and replace the gearbox on my '06 RT is 54 FRUs, without actually opening it up.
    Larry
    2006 R1200RT
  1. 2018 K1600 GTL Engine Cutout
    By 90459 in forum Straight 6 K1600 GT/GTL/B
    Last Post: 01-22-2020, 04:50 PM
  2. s1000XR 2016 vs 2018 buying decision, (looking for opinions/input)
    By jonnyballgame34 in forum S1000 - The Hothead
    Last Post: 02-14-2019, 07:34 PM
  3. Replies: 25
    Last Post: 01-04-2019, 05:10 PM
  4. 2018 K1600 GTL cannot hear gps directions in headset
    By pilotron46 in forum Straight 6 K1600 GT/GTL/B
    Last Post: 09-23-2018, 03:00 PM
  5. update on stop sale
    By l1969 in forum Gear
    Last Post: 09-20-2017, 07:37 PM
