Results 1 to 4 of 4
Thread: 2010 R1200RT crickets/hissing noise from front tire
    Team,
    Wondering what would be causing the sound of crickets / hissing sound from the front tire? Wheel bearing going bad? It does sound like a brake pad is stuck against the rotor but that doesn't seem to be the case. The sound gets louder/faster with speed.
    I have michelin road 5s on front/rear with probably 1,000 miles on them.
    Thanks,
    Brent
    Liaison 20774's Avatar
    Welcome to the forum, Brent! Does it make these noises when you turn the wheel by hand in your driveway?
    It does. I put it on the center stand and spun the front wheel. The wheel does not rock side to side so I'm confident bearing is fine. The noise is definitely different but it's most likely due to it not spinning at 40mph I suppose. I guess something is rubbing the rotor.
    I'm also guessing that's normal for this bike? Hearing cicadas buzzing while you ride?
    Jul 2013
    Solvang, CA
    support the front wheel off of the ground, push back BOTH caliper pads on BOTH calipers and spin the front wheel....report back...
    Road 5s are a noisy tire, but at slow speeds, hardly noticeable....
    FTR, i changed my front wheel bearings and it made a huge difference at about 100,000 miles!!!
    wyman
    ~wyman~
  1. Front Tire Noise
    By agspencer55 in forum Oilheads
    Last Post: 05-19-2018, 10:50 PM
  2. K75 Hissing noise from fuel tank
    By DanK75 in forum Flying Brick K-bikes
    Last Post: 11-20-2012, 06:04 PM
  3. Hissing and gurgling from front forks
    By markst1 in forum Airheads
    Last Post: 10-17-2005, 02:02 AM
  4. Hissing noise from K11 gas tank
    By basketcase in forum Flying Brick K-bikes
    Last Post: 04-07-2004, 03:06 AM
  5. hissing noise
    By 110066 in forum Flying Brick K-bikes
    Last Post: 03-16-2004, 02:48 AM
