Results 1 to 7 of 7
Thread: 1995 K75 rear caliper o ring
    Registered User rall275's Avatar
    Apr 2017
    Harrisburg, IL
    I am rebuilding the front and rear brake calipers on the 1995 and each of the fronts use a small o ring seal. The rear caliper is a little different and it appears to use two of them, though I can't recall seeing two and the schematics do not show two. Does it only use one, and if so, which side?
    Photos of the two halves of the caliper. Arrows show the locations where o-rings appear to go. I should have paid better attention when I disassembled.
    Thank you.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Rall,
    The overhaul kit comes with two O-rings. Put one in each hole.
    The front calipers are slightly different from the rear and take different size pads. Make sure you use fa-18 pads on the rear and fa-171 on the front.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Apr 2017
    Harrisburg, IL
    Rall,
    Thanks. I do have the correct carbonne lorraine pads for front and rear. Pictures of the rebuild kits only shoe one o ring per caliper so I hope they do come with 2. Will update when they come in. Btw, the clymers manual doesn't even depict the different rear caliper. Who proofread that? Thanks for the help.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Mine, Hers, Spare
    Apr 2017
    Harrisburg, IL
    Calipers mounted
    I got the rebuild kits and each had an o ring inside the package and another stapled to the outside. You were right, two per kit!
    I rebuilt and mounted without too much difficulty, though the limited space in the rear was more challenging. The pads in the rear depended within the caliper with the lower edges touching, which was not quite the way of the fronts which were vertical. Perhaps some activation will address this. I await arrival of my Spiegler lines, a little different from the 1988 set.
    I few photos of the calipers:
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Quote Originally Posted by rall275 View Post
    The pads in the rear depended within the caliper with the lower edges touching:
    ??? Please explain.
    Are you sure you used the correct pads for the rear? They are a different part number and are a millimeter or two different size than the fronts.
    Mine, Hers, Spare
    Apr 2017
    Harrisburg, IL
    Explanation
    As the pads hand from the pins once installed, the bottom edges touch, not with force but just gravity. The top edges lay flat as they should. I don't see anything out of sorts. I drew this little sketch just to illustrate what I mean:
  1. Brembo Caliper O-Ring Source Info' Please
    By musclehealchance in forum Oilheads
    Last Post: 09-16-2016, 04:04 PM
  2. Re: Brembo Caliper O-Ring Replacement R1100RS
    Last Post: 07-07-2016, 09:11 PM
  3. seized rear caliper
    By Blacque Jacque Shellacque in forum Oilheads
    Last Post: 04-12-2012, 05:35 PM
  4. Please help me remove the rear caliper
    By Checker in forum Flying Brick K-bikes
    Last Post: 06-03-2008, 09:49 PM
  5. rear caliper fitting
    By godfather in forum Oilheads
    Last Post: 11-05-2006, 01:20 PM
