Results 1 to 1 of 1
Thread: K75 Handlebars
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    K75 Handlebars
    K75s came with three different handlebars;
    Short which had a 2 3/4" rise and only came on the K75S (and the K100RS). These are known as the S bars. The very early S bars (before 9/87) were 1/2" narrower than the later ones.
    Medium which has a 4" rise and came on some K75 standards, Ts, and Cs. These are known as C bars.
    Tall which has a 7 1/2" rise and came on all RTs, some standards, Ts and Cs. These are known as RT bars.
    If you don't have an S or an RT, it will have C or RT bars depending on how it was ordered.
    It was a common swap for less flexible (read older) S riders to add C bars for a more upright riding position. But the problem with this swap is the stock S switch pad will not fit properly with C bars. A&S Cycles (Sacramento,CA) makes barbacks specifically for early K bikes that put the stock S bars approximately where the C bars would be (1 5/8" up and 1 5/8" back) and have provisions to mount the switch pad properly (unlike almost any other barbacks). It is a much easier and cleaner installation as you don't have to strip the grips and all the controls off the bars. 15 minute install. HIGHLY recommended.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
  1. K75 RT handlebars
    By georgej in forum Flying Brick K-bikes
    Last Post: 07-19-2017, 05:35 PM
  2. handlebars
    By hankhoward in forum Wedge K-bikes
    Last Post: 10-05-2015, 11:44 PM
  3. ST Handlebars
    By BuffaloBob in forum Hexheads/Camheads
    Last Post: 05-29-2009, 10:31 PM
  4. k 100 handlebars
    By shakeybone in forum Flying Brick K-bikes
    Last Post: 09-06-2007, 10:59 PM
  5. RS/RT Handlebars
    By bbmw in forum Flying Brick K-bikes
    Last Post: 05-30-2007, 12:34 AM
