Can U give the year and model of your K75. A pic of your handle bar helps. BMW riders change bars at the drop of a hat, uh helmet.
Nutz,
Yes, those are the RT bars.
To route the cable the first time you should remove the fuel tank. After the first time, you can just tape the cable to the old one and just pull it through.
The cable goes on the right side of the steering head and then between the air filter box and the intake plenum, then behind the coils to the left side. Do not put any cable ties on the cable so that you can easily fish a new one through by just taping the new one to the old one and pulling it through.
Nutz,
Yes, that is the correct cable.
I am going to combine this thread with your original one to keep the train of thought going.
This may also help (if you haven't ran across this yet)
https://ibmwr.org/index.php/1998/04/01/sidestand-and-clutch-adjustment/
