Results 1 to 5 of 5
Thread: Flashers as position lights
    On many of my previous,non-BMW bikes, the front flashers were acting as position lights (I.E remained consistently on while riding).
    I've made a few searches and found no information on how or even if it's possible on my bike (2005 R1200RT).
    Anyone ever came across a way to enable this?
    TIA!
    Feb 2005
    EastDakota
    Check out Kisan Signal Minder website. I'm not sure if their products have that capability or not.
    Jan 2005
    Sioux City, Iowa
    Quote Originally Posted by alvtrex View Post
    TIA!
    You just need a two filament bulb and socket that would fit in the twist lock mount. I would look at a K1200LT tail light socket. You might find a match at a good auto parts store or a you-pull-it salvage yard. That type bulb may have a bayonet or push in base. The challenge may be finding a socket that firs you turn signal housing.
    Chuck Swenson
    MOA # 9162
    2010 R1200RT, 2003 F650cs (BMW #12 & 13)
    Combine Turn Signal/Position Lights
    weisertechnik.com sells LED inserts fitting the regular BMW turn signals. Combined white/yellow (driving light/turn signal) and red/yellow (brake light/turn signal), CANBUS approved etc.
    Extra wiring will be needed to feed the added functionality of driving light or brake light.
    Heinrich
    Quote Originally Posted by MotorradR9T View Post
    Heinrich
    Thanks, I'll look into this!
    Edit: Although they offer a module exactly for my request, they don't seem to offer anything for the RT; only LEDs for flashers on external housings (while the RT has blinkers integrated in the fairing).
    No big deal... I was taking a chance!
  1. Emergency Flashers won't go off
    By aieae in forum Oilheads
    Last Post: 05-30-2014, 11:46 PM
  2. 4 way flashers
    By ISAMEMON in forum Airheads
    Last Post: 05-22-2011, 02:53 AM
  3. Flashers
    By GSjerry in forum Thumpers - F & G bikes
    Last Post: 04-16-2010, 04:39 PM
  4. K75 emergency lights/flashers
    By DPRYAN in forum Flying Brick K-bikes
    Last Post: 08-19-2008, 05:53 PM
  5. Replies: 9
    Last Post: 04-07-2007, 07:06 AM
