Flashers as position lights
alvtrex
On many of my previous,non-BMW bikes, the front flashers were acting as position lights (I.E remained consistently on while riding).
I've made a few searches and found no information on how or even if it's possible on my bike (2005 R1200RT).
Anyone ever came across a way to enable this?
TIA!
TIA!
You just need a two filament bulb and socket that would fit in the twist lock mount. I would look at a K1200LT tail light socket. You might find a match at a good auto parts store or a you-pull-it salvage yard. That type bulb may have a bayonet or push in base. The challenge may be finding a socket that firs you turn signal housing.
Combine Turn Signal/Position Lights
weisertechnik.com sells LED inserts fitting the regular BMW turn signals. Combined white/yellow (driving light/turn signal) and red/yellow (brake light/turn signal), CANBUS approved etc.
Extra wiring will be needed to feed the added functionality of driving light or brake light.
Heinrich
Heinrich
Thanks, I'll look into this!
Edit: Although they offer a module exactly for my request, they don't seem to offer anything for the RT; only LEDs for flashers on external housings (while the RT has blinkers integrated in the fairing).
No big deal... I was taking a chance!
