Results 1 to 6 of 6
Thread: Problems and Error Codes 2015 RT
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    So I just completed a 1600 mile ride on my RT, with 64,000 miles on the clock. Riding home through a huge rainstorm, I had a couple of issues crop up.
    First issue is that both the ASC and ABS warning lights are lit yellow. I was in Rain mode, and the lights came on an hour in. What can cause this? Can I read and clear the codes with an ELM 327 type code scanner device?
    Second is cruise control does not work. I suspect this is a related issue. My guess is a wheel sensor got water in a connector. Or a sensor failed.
    Third is that when I stopped to re-fuel, the Keyless Ride would not shut off the bike with a simple push. I pushed the button, the bike would not stop running nor power down. I shut it off using the red button. Also could not gas up, thankfully I had enough to get home. Later, when I got home, I had planned to disconnect the battery so as not to ruin the 2 month old battery... But, instead, I pushed and held the button. This shut off the bike. I did re-start it and then it would shut down properly. Was this related to the errors? Has anyone had this happen? If it happens again, is there a way to re-fuel?
    Thanks!
    John.
    John.
    Atwater, CA
    2015 R1200RT
    I ride a 2014 RT and experienced the same problem.
    If you are still riding your bike, I recommend you park it immediately.
    Turns out the problem is a bad bearing in the rear drive. My dealer was able to discover this issue by draining the rear drive, which showed metal particles in the oil. Also, the rear wheel was difficult to rotate.
    When the bearing is failing, it allows the rear wheel to move just enough laterally to throw off the sensor that feeds Information to the cruise and ABS.
    Milo172
    '78 R100/7
    '94 R1100RSL
    '14 R1200RT
    Jan 2015
    Pickering, ON, Canada
    Rear Drive Bearing Failure
    Quote Originally Posted by 61249 View Post
    Can I ask what the mileage was on your bike when this happened? I'm also curious if this is a common problem, or rare? Any mitigating circumstances that you can think of that may have led to the problem?
    Bob
    2014 R1200RT
    Nov 2009
    Atwater, CA
    I just serviced the final drive before this trip. I'll check the wheel for movement.
    I'm suspecting water got into some connector.
    John.
    Atwater, CA
    2015 R1200RT
    My RT had about 35K when I lost the rear bearing. Until this post, I had not heard of any other occurrences of this type of bearing failure. But when this problem showed up, my RT was also giving error codes on the ABS, stability control and cruise control. The initial attempt to correct the problem was to connect my RT to the “Mother Ship” and update all the internal computers ( a lengthy process). This worked for about a week before the errors returned. Since the rear end replacement, the RT has remained error free.
    Milo172
    '78 R100/7
    '94 R1100RSL
    '14 R1200RT
    John,
    Has your bike’s error code problems disappeared?
    Was drying it out the answer.
    Milo172
    '78 R100/7
    '94 R1100RSL
    '14 R1200RT
  1. Error code 800EA8 on 2015 R1200GS
    By txtinman in forum Wetheads
    Last Post: 06-26-2018, 10:45 AM
  2. Speedometer Error 2015 R1200R
    By pete4638 in forum Wetheads
    Last Post: 09-21-2015, 12:18 AM
  3. Replies: 0
    Last Post: 05-06-2015, 03:34 PM
  4. error codes/'06RT
    By rickyd in forum Hexheads/Camheads
    Last Post: 07-01-2010, 05:50 PM
  5. Error Codes - My First Post
    By papafoxtrot in forum Hexheads/Camheads
    Last Post: 11-19-2007, 09:56 PM
