Results 1 to 10 of 10
Thread: Help-r1100s (2004)
    Registered User nachtaluci's Avatar
    Sep 2019
    Portland, Maine
    Angry Help-r1100s (2004)
    NEED HELP! 2004 R1100S-46K
    HARD STARTING PROBLEM. CRANKS BUT DOES NOT START....Eventually does.
    Here is what I have done-so far
    *Pulled all the plugs and checked-no oil fouling-looked fine.
    *Checked coils-all are working fine (replaced RT side-with new one).
    *Checked injectors-spraying/working fine.
    *I changed out the starter.
    *I checked the throttle cable-made sure it was seated-both sides.
    *Cleaned air box and air filter, cleaned throttle bodies.
    *Checked battery-it tested fine, 12.8 Volts.
    *Did a compression test-left side 210, right side 190
    *Replaced fuel filter
    * I disconnected the loop for the emissions canister-taking away the pressure in the gas tank.
    *No leaks, strange noises, etc. When it does eventually start it runs like it was brand new. Idles fine and is smooth through all the gears, no hesitation or loss of power. Valves were adjusted at 39K
    Any thoughts from anyone would be SUPER helpful. What am I missing?
    THANK YOU!
    Marc Cardullo
    MAINE
    Rider, Realtor, Pilot.
    R1100S
    Jul 2018
    Corralitos, CA - Santa Cruz County
    test for a spark while the starter is cranking or if you have a timing light see if that strobes when hooked up to a power source and the clip on a plug wire. Maybe the HES (hall effect sensor) which triggers the actual spark is broken.
    Signature
    Feb 2005
    Trinity, NC
    Check the valves again.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    If you have a access to another starter, try swapping.
    I had one with the same issue. Turned out to be the starter dragging the voltage too low for reliable operation of the motronic.
    Ufda happens..........
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    Replace the plugs.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    ďThe major civilizing force in the world is not religion, it is sex.Ē
    Sep 2019
    Portland, Maine
    OK-Will Do plugs and check valves again. The starter is new (One week) and replaced the stock one as it was making a strange news when I stopped starting...if that makes sense! I do have access to a timing light and will check that-will be tearing it apart this weekend.....again.
    THANK YOU-Will let you all know how it goes. I did call the dealer (Max BMW) and their only suggestion was bad gas...which it is not.
    Any other ideas/suggestions I welcome.
    -Marc
    Marc Cardullo
    MAINE
    R1100S
    Albuquerque, NM
    Won't start with the sidestand down. Of course that switch could be bad so it won't start in any position.
    Kent Christensen
    21482
    Feb 2008
    The Motronic Ma2.4 bikes should start with the sidestand down when in neutral.
    Oct 2011
    Florida & Massachusetts
    Three ideas if the earlier suggestions donít help:
    1. Have you tried holding the throttle open a bit? It may be that your fast idle lever doesnít open the throttle enough.
    2. Does your bike have a 2nd Load Relay? This is a relay to power the stick coils. If you donít have that relay, check the voltage drop across the key switch. Without that relay, on your bike, three coils draw their current through the key, the drop can get quite large as the switch wears.
    3. Does it start harder when hot, or cold or all the time? Maybe your oil temperature sensor (or air temp) is defective.
    Jul 2017
    Aiken, SC
    My '01 R1100S was very hard to start if temp below 75 degrees. Ran great once going. Took many attempts at cranking to get it to fire. I bought a GS-911 and got fault code for faulty temp sensor. Bought a used one on eBay, installed it tonight. Bike fire first crank, and the fault code is gone.
    I too, did valves, plugs, wires, TB balance, battery and bought a used starter just hadn't installed it.
    Find someone with a GS-911 to check it.
  1. 2004 R1100s
    By Fastmover in forum Oilheads
    Last Post: 04-01-2005, 01:54 PM
