Results 1 to 15 of 15
Thread: Draining your bike's oil - hot or cold?
    Mehrten
    Nov 2004
    Arizona, USA
    I just read an article in the September 2019 issue of Road Racing World that discussed whether to change your bike's oil hot, warm or cold.
    The testers went to a lot of trouble to measure and control how much oil went in and how much came out, including what was left on the funnel and the bowl the oil was drained into.
    The conclusion: Cold - More oil drained out cold. And they determined the amount of contaminants left behind was less than either the hot or warm drain scenario.
    The article is titled "Draining Engine Oil: What's Better? Hot or Cold?" by Jason McDonnell.
    Interesting as everything I've read in my owner's manuals talks about getting the engine up to operating temperature before doing an oil drain, i.e. hot.
    It sure would be easier doing the drain cold, especially on our new K1600GT Sport.
    Thoughts?
    Central Ohio
    Take a ride.
    Drain the oil when you get home.
    Enjoy your evening and a good night's rest.
    Finish the oil change in the morning.
    Best of warm and cold.
    Larry
    2006 R1200RT
    draining the oil
    Quote Originally Posted by mehrten View Post
    Thoughts?
    My thoughts:
    I do not claim to be an expert and really hate to feed into an "Oil thread" but I have probably done a thousand oil changes in 50 years. My theory: You want the oil hotter because it will flow better. Also, if you run the motor first, any junk in the oil will, hopefully, be mixed up and in suspension (instead of sitting in a layer on the bottom) when you let it out. However, it's easier to handle oil that won't burn the s**t out of your hands. My solution: Start the bike and run it for a couple of minutes to warm it up and get all the contaminants/solids, if there are any, moving around with the oil. Then drain it out and change the filter. Then refill. It's not an exact science and if 95% of your contaminants are removed, you're good to go. It is said that the longer you leave the oil in the more it loses its lubricity. However, the factory recommended intervals are very conservative and no harm can come if you change oil and filter +/- 10% mileage of the recommended, no matter how you do it, in IMOH. More oil being drained out cold is counter-intuitive. Contaminants in the oil being the same hot or cold, not so counter intuitive, unless you don't consider take into account that there may be solids which tend to settle. A magnetic drain plug will show you what crud there can be in the oil.
    Mehrten
    Nov 2004
    Arizona, USA
    Felaw,
    Everything you question was addressed by the article.
    They talked about the amount of contaminants in the oil hot or cold.
    Per the article the filter does most of the contaminant removal with the rest staying in suspension because of its small size.
    They also talked about running the engine for a minute or two, i.e. the warm scenario, it was the worst.
    So here's a counter proposal...
    Go for a ride. Park the bike. In the morning when the bike is much cooler drain the oil, change the filter, etc.
    No hot drain plugs or hot oil over my gloves.
    Seems simple yet like you say, doesn't seem right because of all the "training" we've received in the past.
    Yet their conclusion was just that...park it for the night and drain it in the morning.
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    Lots of real world input here: https://tinyurl.com/y439hvy4
    Joe
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Aug 2018
    Fargo, ND
    Quote Originally Posted by lkraus View Post
    Take a ride.
    Yep! I do it this way fairly often. As to cold or hot? I always drain it hot. I often let it sit over night or even a few days if other things delay finishing the oil change.
    Once in a while I don't even worry about it and drain the oil hot, swap out the filter and dump fresh oil in right away. After all, the old oil really was not that bad. If the old oil was that bad you should have changed it a long time ago. I don't see the harm in a few ounces of the old oil left in the crankcase. It simply is not that contaminated.
    From the only real Fargo, ND!
    Mehrten
    Nov 2004
    Arizona, USA
    Thanks for the responses...
    Has anyone else actually read the article?
    I have always drained the oil hot because that was the preached way based on "lots of real world experience."
    Now along comes a moto journalist, acting as a scientist or engineer, who's added in some facts that seem to support a different way.
    Not sure it even matters given the quality of the oil most of us use, and the oil and filter change interval most of us adhere to.
    Makes for an interesting discussion.
    Felaw,
    Well, like I said, I'm no expert and I haven't read the article and probably won't because I would have to subscribe to do so. Therefore, I can't realistically refute their findings or criticize their methodology. But a few facts are beyond argument: Hot oil flows faster than cold. Metal particle contaminants will get trapped in the filter or eventually settle to the bottom. When I was doing oil change for a fleet of trucks we would puncture the cans, drain them into the crankcase and when the oil had stopped draining we put the cans upside down on a rack with a drain can. Every week we would get a good pint or so of oil from the "empty" cans but it took a couple of days for the residual oil to run down into the drain can. No doubt, you will get more oil out of the crankcase, hot or cold, if you let it drain over night but, waiting for the oil to cool down before you drain it makes no sense to me.
    Registered User jandhumphreyme's Avatar
    Sep 2013
    Central Maine
    I changed bike oil hot once. Burned myself and swore never again, that was 40 years ago. My bikes and cars have all been fine, periodic testing by Blackstone seems to confirm my decision. I've heard the arguments for warm, hot, etc. but like a lot of things correlation, causation, and coincidence are often confused.
    So often times it happens that we live our lives in chains
    And we never even know we have the key
    Registered User jonnybow's Avatar
    Apr 2019
    Delaware
    Holy crap, I think getting guys to change their oil themselves is a step in the right direction, now there's people telling them when and how hot or cold it has to be to get it done correctly.
    Change your oil whatever way you get it done and go ride your bike.
    I don't like to burn myself on hot oil so I let it cool down a bit before getting the plugs out.
    Jon
    K1600GT & R1200GSA
    I usually change oil "warm". If after a ride I wait a bit. If the bike is cold I will start it to stir things up and get into suspension anything that would be suspended. Never hot enough to burn me and never stone cold either.
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    I've never worked on a K16, but aside from that - hot or at least pretty darn warm.
    Shouldn't even be an issue.
    Even the cheapest pair of vinyl gloves - like the blue ones from Harbor Freight, or even the clear lightweight "food handling" gloves - will give you a lot of protection for the job.
    And that statement about "more drained out cold" ... if that were true, why would the people who design & manufacture liquid lubricants specify viscosity the way they do...?
    Central Ohio
    Maybe, cold oil holds the contaminants more tightly, and gravity pulls them out with the oil. Less viscous warm oil might let them slip out of suspension before they reach the drain hole?
    It does seem odd that I've never heard a cold oil change recommended anywhere before this.
    Larry
    2006 R1200RT
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    It just may be that over the long run it does not make a significant difference.
    Kevin Huddy
    RK Ryder
    London, Ontario
    When I've asked BMW mechanics at dealerships how they get the bikes up to operating temperatures for oil changes during service, they have told me that don't have the time to warm the up the engines. They simply drain them cold.
    I have always drained my oils shortly after returning home from a ride with the bikes at operating temperatures. It is not unusual for me to let them drain overnight.
    Paul F. Ruffell
    Niagara Riders & Knights of the Roundel #333
  1. Replies: 31
    Last Post: 11-24-2015, 07:53 PM
  2. Oil draining G650GS
    By JIMMC in forum Thumpers - F & G bikes
    Last Post: 07-17-2015, 09:36 PM
  3. Draining the Thermostat?
    By Darryl Cainey in forum Airheads
    Last Post: 11-21-2013, 02:27 AM
  4. Replies: 11
    Last Post: 12-01-2011, 03:23 PM
  5. Draining gas tank
    By kkirkby in forum Oilheads
    Last Post: 09-23-2006, 11:21 PM
