Results 1 to 3 of 3
Thread: Tire pressure monitor
    florida
    Bikes
    2014 R12GS with TPM
    2017 R12GS with TPM.
    I swapped the tires/wheels assembly between the two bikes.
    (Why does not matter)
    Everything bolted up fine.
    ABS works fine.
    But the tire pressure does not register on either bike. And a few miles later the yellow triangle low tire press warning light comes on.
    Is there a fix that is garage friendly, without going to the dealer to reset?
    David H
    Registered User wbrownell9's Avatar
    Jun 2013
    New Castle, DE
    You definitely have to tell the bike about the different sensors before they'll talk to one another.
    If not a dealer, maybe a GS-911 or the like can do it? I have the Motoscan app that uses a Bluetooth dongle that plugs into the diagnostic connector. If you go that route and have a round connector, you'll need an adapter cable too. AFIK the 2017.5 and up bikes have the regular rectangular OBDII connector, earlier ones have the round one.
    2016 R1200 GSA
    Mar 2010
    Wills Point, TX
    Quote Originally Posted by wbrownell9 View Post
    GS-911 does this very easily if the sensors are awake, you may need a wake up tool. https://www.amazon.com/VXDAS-EL-5044...FBRC4EVQFGY8V3 . The bike can have 2 different sensors front/rear (so you can swap the wheel out) but bike needs to learn each sensor.
  1. Tire Pressure Monitor
    By apbehnen in forum Wetheads
    Last Post: 09-23-2019, 05:35 PM
  2. Smart Tire Pressure Monitor
    By hottech in forum Oilheads
    Last Post: 04-23-2012, 01:32 PM
  3. Tire pressure monitor system
    By Rtinger in forum Hexheads/Camheads
    Last Post: 01-15-2011, 04:55 PM
  4. Tire pressure monitor...
    By NESS in forum Campfire
    Last Post: 05-28-2009, 11:28 PM
  5. Tire Pressure Monitor Systems
    By jcridge in forum Gear
    Last Post: 04-26-2009, 10:33 PM
