Results 1 to 5 of 5
Thread: 09 R1200RT (K26) - Error Code: A303 Brake light
    New Friends,
    I purchased an 09 BMW R1200 RT (K26), and it is throwing a Fault Code (A303). I found the Fault code using MotoScan, and checked http://bmwfault.codes/ for more details. It is all very generic information. Does anyone have additional wisdom that could help me resolve this error?
    Trouble Code: A303
    Error Rate: 1
    Battery Voltage: 11.92 Volt
    No Signal or Value: 04
    Test Condition Met: 10
    Error Present and already stored: 23
    Error Caused Warning Lamp to Illuminate: 31
    I do have the BMW Motorrad Service manual, but I did not find anything related to diagnosing the error.
    Thank you
    Liaison 20774's Avatar
    Welcome to the forum! I haven't seen a listing from Motoscan of these codes, but the fault code look up you mentioned indicates it's associated with the brake light. Beyond that, I don't think I can help much. Maybe dig into the brake light and make sure it works and/or check the bulb grounds.
    Hopefully someone else who has experienced this will drop by for some other ideas.
    Mansfield,MA
    Battery voltage seems low. Some hold the brake lever on while starting? Age of battery?
    Let us know how you make out.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Battery voltage seems low. - Gary
    Thanks for the feedback, what target should the voltage be?
    I will take the lights off again and see if I can find anything that doesnt look right, and let you know. THanks.
    Mansfield,MA
    A good “next morning” reading would be 12.7v or so. If the battery voltage drops past 10v while cranking, it has an effect and can lead to odd codes. These bikes ask a lot of the small(ish) batteries.
    Mod Squad
  1. Brake light wire code for ‘16 R1200RS
    By steen1 in forum Wetheads
    Last Post: 07-27-2018, 05:49 PM
  2. Replies: 4
    Last Post: 05-30-2016, 08:54 PM
  3. Error code reset
    By savategreg in forum Motorrad
    Last Post: 09-18-2011, 07:20 PM
  4. error code 2009 R1200GS
    By DAVEFISHER in forum Hexheads/Camheads
    Last Post: 07-29-2011, 04:35 AM
  5. K1100 - 1133 Mortonic Error Code
    By rkildu in forum Flying Brick K-bikes
    Last Post: 01-16-2007, 11:43 PM
