Results 1 to 12 of 12
Thread: Turn off front running light of r1200rt
    Hi everyone,
    I would love to be able to turn off the main front running light during the day as I am equipped with the LED o-ring. Basically I want my back just to have the LED on during the day like in Europe.
    Since we have led, not sure if it will be illegal to remove frontrunninglight.
    How can I do it?
    On my '16RT this is the procedure for turning off the headlight and only using the DRL, and is on page 64 of the Owner Manual
    From the Menus, select Settings/Vehicle and set the DRL to "Off"
    When you start the engine, the low beam will automaticaly come on, with the DRL rings illuminated, but not a full brightness.
    Hit the DRL button on the left swithcblock, which will turn off the Low Beam, and turn on the DRL rings at full brightness.
    I hope this is the info you are after.
    May 2015
    West of Rockies
    I embrace the feeling of being seen, but perhaps not in euro-fashion. I donít live in Europe, but in a land of drunk drivers, uninformed and immature motorists, and tweet-distracted cage operators.
    For me: aux lights, headlight, and photon blasters.
    AZ
    Is your aim to be less visible? Is this just an esthetic thing? Keep in mind you are not riding in Europe where the drivers have much more dedication to proper technique!
    MOA #107139
    RA #28511
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    Quote Originally Posted by Bibbs View Post
    You forgot photon torpedoes...
    I agree, the more lights, the better. I live in Gods waiting room (Florida), which is also 'blessed' with a healthy population of uninsured motorists....
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, Ď17 R1200RT
    I reckon the DRLs on full brightness are more visible than the combinbation on Low Beam and DRLs on reduced brightness.
    Registered User wbrownell9's Avatar
    Jun 2013
    New Castle, DE
    USA requires headlights to be on when the engine is running, I would be surprised if there's a way to switch it off. It's been this way since the '70's. Look carefully at the left switch cluster, you can see the outline of where the headlight switch is for other markets. If you dug into the wiring and figured out how to insert a switch into the circuit you'd probably give the CANBUS fits.
    2016 R1200 GSA
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    Quote Originally Posted by wbrownell9 View Post
    I always thought this too. My 2017 Ducati Supersport though, has a DRL switch that allows you to run with the DRL and not the headlight. May not be totally true. It is a 50 state bike.
    John.
    Atwater, CA
    2015 R1200RT
    May 2007
    Western NY
    The requirement for lights on in the daytime is not national; it varies state by state. I believe some state have no requirement. Here in NY, for daytime riding, the state requires a front lamp visible for at least 200 feet, and a red rear lamp making the license plate visible for at least 50 feet (Vehicle and Traffic Law, section 381). Ducati's DRLs are perfectly legal in NY.
    Karl
    2007 R1200ST
    Jan 2017
    Bothell, WA - USA
    A Good Source of USA Rules for Nearly Everythin to do with Motorcycles
    All cheap talk,... here's a better source.
    https://www.motorcyclelegalfoundatio...timeheadlights
    May 2007
    Western NY
    Quote Originally Posted by Rainman48 View Post
    Full of inaccuracies. As I stated above, NY does not require the headlight be on, only any light visible at 200 feet. And headlight modulation is legal in all 50 states by federal law, which in this case preempts state law.
    Karl
    2007 R1200ST
    Interesting, the person who started this discussion hasn't been back.
    Buck in Greensboro, NC
    2013 R 1200 RT Midnight Blue - traded, 2014 R 1200 RT Ebony Metallic, 2016 S 1000 XR
  1. Turn signal / running light change over
    By Ctrod in forum Oilheads
    Last Post: 07-16-2018, 03:16 PM
  2. Converting Front Amber Turn Signals to Running Lights 11 RT
    By fordtech50 in forum Hexheads/Camheads
    Last Post: 10-08-2015, 06:06 PM
  3. Replies: 10
    Last Post: 09-10-2014, 07:43 PM
  4. 2006 R1200RT Auxiliary light mounting near turn signals question
    By CaptRehkopf in forum Hexheads/Camheads
    Last Post: 03-24-2013, 04:29 PM
  5. 2009 BMW R1200RT - Front Signal Light Lenses
    By b25bsaboy in forum Hexheads/Camheads
    Last Post: 12-21-2012, 03:30 AM
