Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: K1300S Side stand
  1. #16
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by mlytle View Post
    Get rid of the lowering pegs and ride it like it was designed to be ridden!
    Wrong - the OP needs to shorten his legs and grind his foot down to a more manageable size 11. Just the left foot, mind you.
  2. #17
    Are we there yet? tonyfr's Avatar
    Apr 2007
    SAT - LAX
    that wasn't in the original post either....... a clear picture of the problem lends itself to better proposed solutions, faster..
    He did state it later.
    The additional problem is that I had to use a Verholin peg lowering kit to be able to get my feet on and off the pegs. This kit moved my feet down and forward enough to preclude me from getting my size 13s between the foot peg and shifter.
    I did post a solution.
    The stands should be the same. I have lowering pegs on my GT and I use the heel of my boot to lower the stand.
    Apparently with size 13 shoes, he must be on the tall side. Might be a little cramped riding.
    2009 K1300 GT
    1984 Kawasaki ZX750-E1 Turbo
    1990 Kawasaki ZX600R
    2005 R1200 RT - gone
  3. #18
    Registered User mlytle's Avatar
    Oct 2015
    alexandria, va
    Quote Originally Posted by BC1100S View Post
    Marshall
    92 K75s, 94 K75s, 96 K1100RS (caretaker), 09 K1300s
  4. #19
    Gee! Tough crowd.
    Actually, these K bikes are quite comfortable for those of us of normal stature. I have little problem riding my R1200RS with the optional pegs, but Iím thinking perhaps my current situation has more to do with the width of the pegs contributing to the lack of room between the peg and shifter.
    Anyway, as I said before, other than this issue, the bike fits me well and is actually more comfortable than the R1200RS. Before some wag brings it up; no, I do not have risers on the handle bars, a touring wind screen, highway pegs nor saddle bags.
  5. #20
    Oct 2015
    alexandria, va
    Quote Originally Posted by zoomie View Post
    Gee! Tough crowd.
    LOL!
    i am sure you already realize this, but since the S is a sport bike, the lowered pegs have already compromised max lean angle. extending the existing sidestand nub or adding a k13GT sidestand will compromise it further. yes, even the stock peg location can hit the ground when working it (on track).
    Marshall
  6. #21
    Yeah, I realize this, which is surprising since Iíve only been riding since 1966. First bike Honda Superhawk. Second Bultaco Metralla.
    True, I might have compromised the lean angle with the pegs that were lower a massive 1 1/4 inch. However, this not a track bike, nor will it ever go near a track. The closest track to me is a 400 mile round trip. Also, the HP pegs that were stock are not spring loaded, so a solid touch is apt to cause a drop.
    As I said before, my other 2 K bikes, K1200R and K1200 R Sport both had the same strange issue. I simply wondered if someone else might have had the same experience and found an elegant solution. The idea of the GT side stand is intriguing, but there is a difference in the tang that the spring attaches to that might cause interference with either the peg or shift lever.
    Anyway, thanks for the input and help.
  7. #22
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    I always thought it was odd the HP pegs did not fold.
    Lee
    2016 R1200RS
    MOA # 30878
  8. #23
    Left Coast Rider
    Nov 2011
    Oh, a rookie, eh?
    Kidding!!
    But getting back to business, would it be possible to weld a tang onto your existing side stand in a position which would enable easier deployment?
  9. #24
    May 2003
    SW Iowa
    Maybe bolt something temporarily to the stand to see if it helps.
    Lee
    2016 R1200RS
    MOA # 30878
  10. #25
    I plan to look into either modifying the stand, replacing it with a stand from a GT or having a swivel installed in my ankle. Of course there is always the ultimate elegant solution - carrying a forked stick to push the stand down. Actually, itís probably just me getting reacquainted after a couple years absence.
  11. #26
    May 2003
    SW Iowa
    My wife had the best solution. She travels with a servant and he would jump off his bike and deploy her stand when she could not find it
    Lee
    2016 R1200RS
    MOA # 30878
  12. #27
    Personally, I think carrying a forked stick in my boot might be cheaper.
    FWIW, my son-in-law rode the bike and had the same problem with the kick stand. Iím leaning towards a GT stand.
  13. #28
    FWIW.
    A salvaged GT stand and mounting bracket arrived. Both the mounting plate and stand are completely different from the S stand. Fortunately, Rubber Side Up is good about returns. So, I guess Iím back to redneck engineering.
    Break out the JB Weld! Things are about to get seriously agricultural around here.
  14. #29
    Apr 2007
    SAT - LAX
    Try the Ilium foot enlarger. You can use the heel of your boot to lower the stand.
    2009 K1300 GT
  15. #30
    Odd, but the shape of the GT standís foot is different from the S stand. I have an Ilium foot pad with the loop, and I think I can shim it to fit the S standís foot. Actually, the two standís are completely different.
  1. Replies: 32
    Last Post: 11-09-2015, 02:53 AM
  2. 1994 K75, center stand, side stand lube
    By ted in forum Flying Brick K-bikes
    Last Post: 10-13-2012, 09:59 AM
  3. Side Stand or Center Stand
    By groeger in forum Oilheads
    Last Post: 11-19-2006, 10:29 PM
