Results 1 to 3 of 3
Thread: '00 F650 Funduro gas tank
    Apr 2019
    Sparks, Nevada
    All the specifications that I have read about my 2000 F650 Funduro show that it has a 4.5 gallon gas tank (17 litres). There is, evidently, a 0.5 gallon reserve reservoir to enable getting to a gas station after a lengthy procrastination. I've been tracking my mileage pretty closely in preparation for a "long" trip of about 200 miles; it's been getting between 47.5 and 50 mpg (leaning toward 47 with a full load).
    Sharpening my pencil, my calculations revealed that I could theoretically travel almost 200 miles before having to switch to the reserve tank. Factoring in a 20% safety margin, that put me at 160 miles to make sure I refilled the gas tank.
    Well, much to my surprise, I ran out of gas at about 152 miles. That put the main gas tank at close to only 3 gallons!
    Can anyone tell me what is going on?? I topped off the tank nearly identically every fill-up.
    - Is the reserve tank 1.5 gallons?
    - Could gas be unused on one side of the tank because of a gas-sucking hose to the carburetor being plugged up?
    - Maybe my phone's calculator is playing tricks on me?
    Any suggestions or ideas are appreciated!
    Jun 2009
    Rochester, MN
    How much gas did you put in after the bike quit?
    Another thought - a broken or plugged petcock.
    Apr 2019
    Sparks, Nevada
    Quote Originally Posted by drneo66 View Post
    I put in about 3.1 gallons after switching to the reserve tank and driving to the gas station (about 8 miles). It started easily when switching back to the main tank after the fill-up.
    Good suggestion on the broken/plugged petcock -
    I think I'll have to run it out of gas again to see if it stops at about 150 miles (~3 gallons). If it does, then I'd say the tank is either 3 gallons or there's something stopping part of the tank from feeding gas.
    Thanks -
  1. 2000 F650 Funduro
    By mrmayhem in forum Thumpers - F & G bikes
    Last Post: 08-04-2019, 07:15 PM
