Results 1 to 4 of 4
Thread: 2005 k1200 gt engine failure
    bike with 67k on the odometer, replaced fuel pump and fuel filter, air filter 2 months ago, now this!
    I was riding at 70/80 when I smell of rubber burning or shrediing just before engine shakes right to left and dies for good.
    Any theory or indication to help me in the search and repair is much appreciated.
    Thank you,
    DOM
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    DOM,
    Check oil to see if it is milky or frothy.
    Check coolant for same.
    Do compression check.
    Report back, then we can do some troubleshooting.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    Could be one, or more, of the rubber inlet tube(s) disintegrated and pieces got sucked in the engine......
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, 17 R1200RT
    May 2008
    Western Massachusetts
    Are all the external plastic bits present and accounted for?
    Does the engine crank? Can it be manually cranked over?
    Pull the plugs and have a look inside with a scope.
    Just first thoughts. Let us know what you find please.
  1. 2005 R1200gs engine output seal failure
    By espressoforyou in forum Hexheads/Camheads
    Last Post: 12-05-2017, 12:39 AM
  2. 2005 K1200 s
    By woody99 in forum Wedge K-bikes
    Last Post: 11-04-2010, 05:04 PM
  3. ABS failure - 03' k1200 gt ??
    By johncolleton in forum Flying Brick K-bikes
    Last Post: 10-24-2005, 08:19 PM
