Results 1 to 15 of 22
Thread: 2002 R1150R dies once at operating temperature
    Nov 2008
    Abington, PA (Philadelphia)
    My 2002 R1150R died on the way home from work the other night. It was a nice 75º day. Cranked over just fine but wouldn't start. After about 30 minutes on the side of the road it started right up and ran fine. I made it a few more miles before it died again. I repeated this process 4 times before I finally made it home.
    I'm having trouble diagnosing this as it only dies once its up to temperature.
    I can confirm that the following (though I haven't been able to check these when it won't start):
    • side stand switch is good
    • Hall sensor is good (replaced 8k miles ago)
    • have spark
    • have fuel flow from injectors (though it doesn't look strong, I'm not sure how strong it should be)
    Any thoughts or advice is appreciated!
    Thanks,
    Jim
    Feb 2005
    Trinity, NC
    Your 2002, it’s still a single spark model right? One spark plug on each side. If so, you have a central ignition coil. Gets hot and stops sparking, cools off and sparks again. If your bike has stick coils, I can’t help you.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Nov 2008
    Quote Originally Posted by m_stock10506 View Post
    Correct, single spark. This echoes what I'm thinking... I've got another coil on the way from Beemer Boneyard, just wanted to see if there is something I'm not thinking of.
    Thanks!
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    Temperature sensor?
    Neal - '16 R1200GS / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Quote Originally Posted by rguy View Post
    Temperature sensor?
    Will not cause a failure, just a code and default fuel map.
    Ufda happens..........
    Feb 2008
    Was the replaced hall sensor new? or?
    Mansfield,MA
    Would you happen to know the age and condition of the battery?
    Mod Squad
    2009 F800GS 1994 TW200
    Nov 2008
    Yes, brand new Hall Sensor about 8k miles ago. It's in great shape, one of the first things I checked. Also, when the original HES failed it was more of a sputter and stall. This is just a stall, no sputter.
    Nov 2008
    Battery is a couple years old and still holds 11v or more while cranking.
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    You are onto something with fuel flow. Look at fuel filter and the pump.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Oct 2011
    Florida & Massachusetts
    Quote Originally Posted by jrsndman View Post
    • have spark
    Thanks,
    Jim
    You probably have a split hose in the tank.
    —Separate the two halves of the upper QD (fuel return line)
    —press in the check valve on the male (left hand) QD
    —turn the key on
    During the 1-2 seconds that the fuel pump runs you should get a strong surge of fuel.
    If the bike will idle and you can direct the flow into a container you should get about 2 liters in one minute. If the bike won’t idle you can jumper the fuel pump relay with the bike off.
    If you get a strong surge and/or 2 liters/min, the pump filter and hoses in the tank are good.
    Nov 2008
    Quote Originally Posted by roger 04 rt View Post
    —turn the key on
    Thanks Roger. I’m not sure I understand why the bike will run fine for 20 mins or more and then stop. If there was an issue with a hose in the tank or fuel flow, wouldn’t it be there all the time?
    Sent from my iPhone using Tapatalk Pro
    Left Coast Rider
    Nov 2011
    I'm thinking coil.
    Had this same issue with a car once. Of course, that was about 100 years ago before every plug got its own fancy-shmancy, private-use-only coil.
    Nov 2008
    Quote Originally Posted by BC1100S View Post
    I'm thinking coil.
    This is a single spark version, no individual coils.
    Left Coast Rider
    Nov 2011
    Yup, got that from your previous post. I was referring to newer cars...and my K bike.
  1. Operating temperature of final drive on 08 R1200RT
    By patrickratliff in forum Hexheads/Camheads
    Last Post: 09-04-2017, 08:20 PM
  2. operating temperature
    By ROBERTSI in forum Wetheads
    Last Post: 06-21-2016, 03:41 AM
  3. operating temperature
    Last Post: 08-19-2015, 06:57 PM
  4. Replies: 15
    Last Post: 06-10-2014, 07:45 PM
  5. engine operating temperature
    By psikora in forum Oilheads
    Last Post: 03-13-2012, 12:36 PM
