Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: 2002 R1150RTP engine shuts down
  1. #16
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by m_stock10506 View Post
    Not a stupid question, but tricky to do. You can check resistance across the primary and the secondary terminals of the coil. But, this will only prove a problem if the coil has failed completely. My own experiences with bad coils has been they only failed when hot, after running for a while. They cool down and the bike starts again, until eventually it won't and you end up stuck somewhere.
    You could take a chance on a used coil on eBay. Buy a new one. Borrow a coil from a friend and see if the problem goes away.
    on all points.
  2. #17
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Forgot to ask, is this the 1 spark or the later 2 spark model?
    Ufda happens..........
  3. #18
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    In my experience, a coil can break down when hot but the symptoms have always showed at hard acceleration when the coil dwell time is at it's lowest.
    An instant stall/stutter when the engine is hot points me to the fuel filter first, fuel pump second and sometimes a relay.
    Unless you are certain you are losing spark when the bike stalls, just take a few seconds and listen to the fuel pump. The sound it makes might give clues.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
  1. 2002 bmw r1150rtp no fuel from injectors
    By edheiser in forum Oilheads
    Last Post: 06-18-2017, 01:40 AM
  2. Engine shuts off when coming to a stop '09 G650GS
    By m_r_dewey in forum Thumpers - F & G bikes
    Last Post: 05-19-2017, 12:55 AM
  3. 2014 F 700 Oil leak and engine shuts off
    By activehybrid in forum F-Twins
    Last Post: 05-05-2015, 03:14 AM
  4. No more clutch! 2002 R1150RTP
    By OfficerImpersonator in forum Oilheads
    Last Post: 05-23-2013, 05:28 PM
  5. Bypassophobio - Engine Shuts Off
    By radan2 in forum Airheads
    Last Post: 05-11-2011, 04:21 PM
