Results 1 to 15 of 18
Thread: 2002 R1150RTP engine shuts down
    Feb 2006
    Fairfield CA
    For the last couple weeks my 2002 R1150 RTP will lose power at freeway speed’s for less than a second the engine shuts off and then comes right back it has done this multiple times. Last week It shut down and would not restart. It was 97° out. But 20 minutes later it fired up and ran for about five seconds and then shut down. Any ideas what might be the cause
    Registered User tangoalpha's Avatar
    Dec 2016
    CA Central Coast
    Quote Originally Posted by BILLK75 View Post
    I own a 2002 R1150 RT and I’m no expert on the subject, however what you’re describing sounds like a fried Hall Sensor. I’m sure GSAddict and others will be along shortly to offer their thoughts. There are other possibilities as well to consider, but given the year of your bike and that the Hall Sensors are a known problem on our vintage RT’s it seems likely that is your issue.
    "Der Bimmer ist wunderbar."
    Tango Alpha
    2002 R1150RT
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Sounds like Hall sensor symptoms, is it a higher mileage bike?
    2002 is the year that the HES wiring was upgraded, you may have the old style wire or not.
    If it's the old style I can help you.
    Here is how to tell.
    Ufda happens..........
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    I would start at the fuel filter.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Feb 2006
    Fairfield CA
    1150rt
    It has a new style hall sensor, it was installed about a year ago. It was a used sensor. Will the sensor act up under dry conditions?
    Mar 2010
    Vancouver, B.C. Canada
    The hall sensors are semiconductor devices. When they get old or are exposed to excessive heat it is not uncommon to experience flaky behaviour such as you described. Heat and moisture creates steam in there which gets into the wiring when the wire sheathing is breaking down and not insulating properly anymore is on failure condition.
    The Hall Sensor plate lives in a very high heat area so yes, even though it is dry it can fail just from the heat and then resume working after it cools down. But the circuit in the hall sensor is damaged and will not be reliable.
    Note that bad or failing coils can exhibit the same symptoms.
    Feb 2008
    The sensors can but it is very rare.
    Scan with a GS 911 and see if it left a stored code.
    I have had the odd sensor fail when heated on my rotating tester only to work again upon cooling. Maybe 2 in all the units I've done.
    Nov 2008
    Abington, PA (Philadelphia)
    This sounds similar to my issue. Tomorrow I'll try testing the HES after heating with a heat gun.
    https://forums.bmwmoa.org/showthread...ng-temperature
    Mar 2013
    You described a fault we had in every service truck we had back in the '90's and it was the fuel pump every time.
    The defining diagnosis was to kick the fuel tank, not an easy task in the winter, but every single time, the truck ran until it quit again, got kicked again and then into the shop where we would see another one and ask for "light duties".
    They never came in with an empty tank of fuel.
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    Possibly a dying battery starting to hiccup.
    Is the electrical connection to the gas tank (right side, below the rear of the tank) secure?
    Looking for more definitive clues: When it shuts off, do you still have lights? And specifically, does the RID stay on or go blank?
    Feb 2006
    Fairfield CA
    Update
    I replaced the Hall sensor and the bike ran fine. Took it for a short ride and after about five minutes it died. Preliminary testing shows no spark. Any suggestions
    Left Coast Rider
    Nov 2011
    Here's a WAG - test your coil.
    Feb 2008
    Coil
    Feb 2006
    Fairfield CA
    Quote Originally Posted by BC1100S View Post
    This may be a stupid question but how do you test a coil.
    Feb 2005
    Trinity, NC
    Not a stupid question, but tricky to do. You can check resistance across the primary and the secondary terminals of the coil. But, this will only prove a problem if the coil has failed completely. My own experiences with bad coils has been they only failed when hot, after running for a while. They cool down and the bike starts again, until eventually it won't and you end up stuck somewhere.
    You could take a chance on a used coil on eBay. Buy a new one. Borrow a coil from a friend and see if the problem goes away.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
  1. 2002 bmw r1150rtp no fuel from injectors
    By edheiser in forum Oilheads
    Last Post: 06-18-2017, 01:40 AM
  2. Engine shuts off when coming to a stop '09 G650GS
    By m_r_dewey in forum Thumpers - F & G bikes
    Last Post: 05-19-2017, 12:55 AM
  3. 2014 F 700 Oil leak and engine shuts off
    By activehybrid in forum F-Twins
    Last Post: 05-05-2015, 03:14 AM
  4. No more clutch! 2002 R1150RTP
    By OfficerImpersonator in forum Oilheads
    Last Post: 05-23-2013, 05:28 PM
  5. Bypassophobio - Engine Shuts Off
    By radan2 in forum Airheads
    Last Post: 05-11-2011, 04:21 PM
