Results 1 to 10 of 10
Thread: Locking rear brake 2015 K1300S
    I have a new to me K1300S Motorsport, and I have a problem.
    Those gorgeous rear sets put my feet too high. I found and purchased a set of standard foot plates, pegs an a peg lowering kit. The left side has gone okay. The right side is causing grief. The actuator rod appears to be too long. We have shortened the rod at the Clovis and bled some brake fluid at the rear caliper allowing us to connect actuator to master cylinder. Success? Well, no. We started the bike, pressed the brake pedal and had a flashing red exclamation and the rear wheel locked. Not good. Turning the bike off releases the brake. What the heck is going on?
    Left Coast Rider
    Nov 2011
    Shot in the dark here......Is there a micro switch which isn't being released or is sticking after removing pressure from the rear brake pedal?
    I don’t know about a microswitch. It appears to be a mechanical issue. It seems the master cylinder actuator rod is too long forcing the pedal to pressurize the hydraulic brake circuit.
    However, when we release the hydraulic pressure at the bleed valve, the pedal also drops down, but will not release again if depressed.
    Left Coast Rider
    Nov 2011
    I was thinking that perhaps the electronic servo assist is activating but then for some reason not deactivating thereby keeping the rear brake on.
    Its certainly a head scratcher especially since you've shortened the actuator rod.
    OK. Basics. Does this year model even have "whizzy" brakes? I did not think it did. So does it?
    I’m not sure what you mean by Whizzy Brakes, but I think you are referring to the servo ABS?
    Anyway, I took the entire brake pedal assembly apart, and made measurements and comparisons. We then did some redneck machining with a Dremel and shortened the rod by another half inch. Viola! “Some say voila, but I like to say viola!” All issues were solved and I got my ride on my cruise Missile.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    No Servo brakes on the K1300.
    Lee
    2016 R1200RS
    MOA # 30878
    May 2003
    SW Iowa
    Quote Originally Posted by zoomie View Post
    It's a nickname for Servo brakes.
    The servo gives you a power assisted brake feel.
    Good to hear you have the problem solved.
    Lee
    2016 R1200RS
    MOA # 30878
    Left Coast Rider
    Nov 2011
    This is my mea culpa face.
    Quote Originally Posted by BC1100S View Post
    Meh!
    Now I know what a “Whizzy Brake” is. Any knowledge has value.
    Thanks for taking the time to help.
  1. 2015 K1300S Motorsport Pegs
    By DANIMAL in forum Wedge K-bikes
    Last Post: 09-02-2019, 02:59 PM
  2. new for me 2015 K1300s motosports edition
    By dynajohn in forum Wedge K-bikes
    Last Post: 12-29-2018, 03:00 AM
  3. 2015 RT rear brake pad replacement
    By captainmarko in forum Wetheads
    Last Post: 05-29-2018, 09:09 PM
  4. rear brake locking up on 1999 K1200LT
    By aapasquale in forum Flying Brick K-bikes
    Last Post: 01-29-2016, 10:49 PM
  5. Rear brake caliper locking up 2007 R1200RT
    By rmeisen in forum Hexheads/Camheads
    Last Post: 07-27-2012, 12:46 PM
