Results 1 to 4 of 4
Thread: 1996 R1100R brakes Saga continuing
    Mar 2019
    NJ
    So,
    the new front pads and Spiegler lines are in. Rear pads looked quite good.
    after 3 days and over a liter of fluid, still can not get to the normal response. Rear lever is soft/spongy, even after both ABS and caliper bleeder not producing any air bubble (both with the Vac pump and brake lever).
    Got to the hard lever in the front, but now the front brakes are stuck solid.
    What I am doing wrong?
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    First a few questions:
    Were the original lines deteriorated on the inside ie: bits of rubber in the old brake fluid?
    Did you remove the pistons from the calipers and blow everything clean?
    Many times bits of rubber inside the calipers will clog the banjo bolt and not allow fluid to return.
    Did you bleed the F & R nipples at the ABS module as well?
    Ufda happens..........
    Registered User jsouth's Avatar
    Apr 2015
    Weatherford, OK
    Quote Originally Posted by grumpygnome View Post
    So,
    Rear systems are hard to bleed. Use a Mity-Vac. Harbor Freight has a reasonably priced knockoff.
    2000 BMW R1100RS | Past bikes: 97 Suzuki GS500E, 82 Suzuki GS1100E, 07 Suzuki V-Strom 650
    Registered User jerulator's Avatar
    San Jose, CA
    I recently had my front brakes lock up. Problem was the ABS module. If your brake lines deteriorated and you rode it like that( without knowing of course) then you may need the ABS module refurbished. Module master in Idaho did mine and it works great. I think it was about $400. I highly recommend them. I'm not paid by anyone either lol.
  1. 1996 R1100R braking issues
    By grumpygnome in forum Oilheads
    Last Post: 08-12-2019, 09:30 PM
  2. NAV 6 - Continuing Saga - Why Contacts Not Loading
    By river-runner in forum Motorrad
    Last Post: 10-10-2017, 07:06 AM
  3. 1996 R1100R Keys
    By timboulay in forum Oilheads
    Last Post: 05-20-2017, 01:17 PM
  4. Continuing R 50/2 saga
    By johncrute in forum Vintage
    Last Post: 04-04-2012, 04:46 PM
